Question about Motorola Mobility RAZR V3
USB Cable and charging problems
I bought a motorola usb cable and pluuged from phone to computer. Ever since the phone wont chrage. any solutions please
  • 3 Answers
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Posted on Apr 17, 2008
SOURCE:
How can i charge my motorola w230 via pc and usb cable?
Before using the computer as a charging system for the phone, the appropriate drivers must be installed on the system.
The W230 can be connected to the computer with a USB cable or data charger cable.
Apr 24, 2012 | Motorola Mobility W230 Phone US with...
Need to download pictures from phone to computer
check any updates of your phone for the software driver and install it to your computer..or betterremove your memory card and use card reader to download pictures or music.
hope it helps
Sep 10, 2011 | Motorola Mobility RAZR V3m Cellular Phone
Hello. I live in Sarajevo. Bought U9 recently and have several problems. The main is that charged battery lasts very short time and it just turns off without any warning. I must say that the charger is not...
Get Motorola original battery and charger.
For USB charging you need to install drivers. Not sure our drivers posted on our site currently provide support for this old model though.
Mark
Motorola Support
Dec 08, 2010 | Motorola Mobility MOTO U9 Pink Cellular...
My motorola rokr e8 wont charge with usb cable on my computer
hi...
To charge your mobile with usb cable you should install a driver called as mobile phone usb driver ,if you install it you can charge your mobile through PC.
If still it doesnt charges then install the PC CHARGING DRIVER.
I will give you the website which contains the driver and the instruction below it to install the driver so that you can charge your mobile by usb
website : http://www.motorola.com/consumers/v/index.jsp?vgnextoid=3fd11e8c04021210VgnVCM1000008406b00aRCRD
thanx
Jul 19, 2010 | Motorola Mobility ROKR E8 Cellular Phone
How can I charge the battery by internet
Hi! Just make sure that you had installed the latest usb drivers on you computer and plug your data cable and phone in. If it`s not charging, that means the phone is not designed to do that. Not all the models can charge by usb cable.
Dec 14, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Hi, my phone wont switch on properly, it just lights up with a wh
This problem occurs because of not ejecting the device properly when connected to pc(computer) via usb cable.
solution:connect your phone to computer via usb at the system tray you see a icon . right click on the icon.the device name appears on the new tab click on it.the hardware is ejected & remove the usb cable
Feb 06, 2009 | Sony Ericsson K750
Where is the usb port on this phone
http://nextelonline.nextel.com/NASApp/onlinestore/en/Action/OSBrowseAccessoriesDetail?PHONE_ID=I880G&categoryRefName=Data+%26+Connectivity
solution to this problem is that the USB is on the connector
its an accessory
-->pt_accessories_en.gif Data & Connectivity for the i880 by Motorola (Choose a different phone) spacer.gif Motorola USB Charging Data Cable - Item # NNTN5405 nntn5405_l.gif Easily link your phone to the USB connector of a computer or PDA, use your phone as a wireless modem and more. The cable also features an integrated charging port so the phone can be charged while simultaneously performing data operations. The charging port can be used with compatible standard, rapid and vehicle power chargers.
Jan 24, 2009 | Motorola Mobility i880 Cellular Phone
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
Motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Sep 16, 2007 | Motorola Mobility Moto Q
Motorola Mobility RAZR V3 Logo
229 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
