Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Bissell Pro Heat 8910 clogged?
I have a Bissell Pro Heat deep cleaning carpet cleaner. I also have pets, which means even after running a sweeper, there's still a certain amount of dog hair in the carpet.
I was steam cleaning the carpet, and a clump of wet dog hair got sucked into the Pro Heat, and the motor sound got "muffled". It still works, but I feel like it is not working at full power. I took off the clear window on the front and cleaned it, but could not find the glob of dog hair that is slowing it down.
Called Bissell, and the lame answer I got was..."If it's still working, then don't worry about it"!! I was in shock at that stupid answer!
Is there a way to clear the hose or whatever part that the dog hair clump is stuck?
Thanks in advance for any and all help.
  • Midge Burton
    Midge Burton Nov 19, 2008
    Thanks for the response. If hair DID go down the chute and into the fan, is that going to hurt anything? If so, how do I remove it?
  • d0dge77 Feb 08, 2009
    How do you take the front clear cover off to remove the hair ? Undid the two screws but its not budging and not sure which direction i'm meant to be pulling it in !!
    President:
  • 1,673 Answers
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Posted on Nov 18, 2008
  • Lauren Junge
    Lauren Junge Nov 19, 2008
    You will have to remove the motor, once you do you will see the fan and can inspect it.
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2x manual
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Sep 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Manual for a Bissel pro heat
Here is the Instruction or User Manual for the 9500 series machines
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Need free manual down load for Bissell 8910 pro heat carpet cleaner
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
750 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
