Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Unable to access my 4 GB Transcend pen drive with Windows Vista Home Premium Edition. Able to access it with Windows XP successfully but always prompting "Unable t find driver" when tried with Vista
    Scholar:
  • 35 Answers
Here are the 3 possible solutions to this problem,
SOLUTION 1 :-
Make sure the you have the Service Pack 1 installed for you vista computer.
You can find it out by opening the run command and type "winver" (without quotes) there. If it's not showing SP1 please update Windows Vista to Service Pack 1 which includes the update to fix this problem as this was the problem when vista was launched but fixed with SP1.
If updating vista does not resolve the issue try the solution provided below:
SOLUTION 2 :-
Manually locate the driver within the Vista operating system.
Microsoft Windows Vista may not find any driver for the device that is plugged in the USB port because the usbstor.inf (for MSC device) or wpdmtp.inf (for MTP enabled devices) is not present inside the C:\Windows\INF folder.
To resolve this issue, you must copy the driver files to the C:\Windows\INF folder.
Browse to the following folder:
1. C:\Windows\System32\DriverStore\FileRepository.
2. Look for the folder that starts with usbstor.inf_.
3. Copy all the files inside this folder to C:\Windows\INF.
4. Disconnect and reconnect the device.
If the problem still persists, try this Solution:
SOLUTION 3 :-
Clear hidden devices and make changes to the Registry
First backup your registry by  following these steps,
1. Click Start
2. Type regedit on the start search field, then press Enter.
3. Click File then select Export.
4. Under Export Range select All.
5. Type in the desired name to be saved.
STEP 2 - Remove Hidden Devices
1. Click Start..
2. Type cmd on the start search field , then press Enter.
2. Type set DEVMGR_SHOW_DETAILS=1 and press Enter.
3. Type set DEVMGR_SHOW_NONPRESENT_DEVICES=1 and press Enter.
4. Type start devmgmt.msc and press Enter.
5. Device Manager window will appear
5. Click View, then select Show hidden devices.
6. Click + to expand Imaging devices, Unknown devices, and USB devices.
7. Verify if there are any devices and unknown devices (including grayed out devices). Uninstall.
STEP 3 - Remove all oem*.inf files
1. Click Start.
2. Type cmd on the start search field and press Enter.
3. In the command line, type in the following commands and press Enter after each command:
  cd \windows\inf
  ren infcache.1 *.old
  ren oem*.inf *.old
  del C:\windows\setupapi.log
  exit
STEP 4 - Remove entries under HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB
Remember,if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start
3. Click on the "+" symbol beside HKEY_LOCAL_MACHINE
4. Navigate to \System\CurrentControlSet\Enum\USB.
5. Highlight and delete all the VID_xxxx entries.
Please note that if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
After this turn off your PC completely then with the PC turned off, plug the USB flash drive to a USB port and then turn on the PC.
Now, a New Hardware Detected balloon will appear and the USB drivers will load automatically.
Please let me know if the problem persists.
Posted on Nov 19, 2008
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Jul 11, 2011 | Acer eMachines Black EL1352G-41w Desktop...
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Just a tip
If yours is a PC, Windows Vsita 64 bit should recognize 4 GB RAM. Have you tried the 64 bit bootable linux? Try with that. If you see less than 4GB, then you must check your BIOS for some setting which is the setting to share to the graphics memory or some limit.
Jun 03, 2009 | Microsoft Windows® Vista 64-bit Business...
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : safiqul.alam@gmail.com
Mar 25, 2008 | Electronics - Others
Pen drive problem
hi.
Vista doesnt recognize all pen drives. only few like Sandisk, Transcend etc get recognized. Even brands like kingston don't get recognized. so to make them work install the driver for the pendrive. If you specify the brand of your pen drive ..i will try to help out with a driver .
regards
bzoy
Dec 11, 2007 | Transcend (589307) Media
My Book320 GB Premium Edition
its probablyt a raid volume. or u need to do chkdsk /r in recovery console
Nov 05, 2007 | Electronics - Others
Electronics - Others Logo
580 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
