Question about Dell Inspiron 2200 Notebook
Screen wont light up
I have an Inspiron / 2200 . My screen didn't light up . Like a light burnt out . Even though its dark I know my P. C. is on . I can see the logo if I look real close , but not the pointer . Is this my LCD screen , or maybe a back light of some sort . I may try to repair myself . What do you think ? THANKS in advance JoeG.
  • Dell Master
  • 998 Answers
Try connecting an external monitor to the Dell Inspiron 2200. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor display is dark, problem is with either the video card or motherboard located inside your laptop.
Here’s a link to disassemble the LCD unit:
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 18, 2008
Dell inspirion 2200 password lock out service tag: FG1XX81
If you mean the windows password screen, software is available to break in. Quite expensive though.
Mar 22, 2014 | Dell Inspiron 2200 Notebook
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Maybe the charger is not putting out enough voltage and amperage.
Or, need a new battery.
Jul 04, 2010 | Dell Inspiron 2200 Notebook
Screen on Dell Inspiron 2200 went totally dark 2 months after warranty expired. Computer still works when I use cables and hook it to TV - but that is very inconvenient. Help?
that means the scren totally went down, there no way to fix, unless you send back to dell.
but there is a evsy way to use the bottom part that buy a extra LCD screen, so you can still using your laptop and display on the larger LCD screen
Dec 29, 2009 | Dell Inspiron 2200 PC Notebook
No brightness to the screen background is dark.
Take the laptop into a darkened room.
Does the correct image show, but very dim ?
If so, then the "back-light" in the LCD has failed.
It's about a $20 part, and it will take a qualified technician less than one hour ($60?) to disassemble the laptop, replace the part, reassemble, and then test the laptop.
Nov 19, 2009 | Dell Inspiron 2200 Notebook
My Dell laptop screen blacks out when I turn it on. And, I can't find my installation CD's. Please Help.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
May 29, 2009 | Dell Inspiron 2200 Notebook
Dark/black screen on laptop
take this into geek squad to get monitor fixed because what has happened is that the back light behind the lcd has burnt out.
May 24, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 laptop Display Problem
just open your laptop battry and give its power by addepture and on it.if the problem is not solved check the addepture,after that change your laptop
Apr 22, 2008 | Dell Inspiron 2200 PC Notebook
Black Screen
sounds like an issue with the backlight, possibly the inverter,
Oct 08, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
111 people viewed this question
Alun Cox
