Question about Stoves 720EF Electric Double Oven
Stoves oven genus 900 error codes
Where can i get a copy of the error codes for a genus 900 and how to re-set them.
I've got a 7 flashing (genus mode "button") and neither of the two ovens will work now.
It worked fine this morning when i cooked some toast this morning
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Posted on Apr 15, 2009
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
Nov 27, 2009 | Stoves Premier 900GRa Gas Double Oven
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Hi I have just got my new Genus m/f oven the multi funcition I am fine with but I find I have no instructions or recipes for the Genus.Can anyone tell me where I can get some. or download some I am in...
As a US consumer, I am not very familiar with Genus ovens, but I think they are manufactured by Glen Dimplex. Their website is www.gdha.com or try their phone at 0871 222 2502. They may be able to supply you with additional info for your oven. Hope this helps.
Apr 19, 2009 | Stoves Ovens
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Mar 06, 2009 | Stoves Ovens
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
I'm looking for an instruction manual for a Stoves 900 GTF built-in fan assisted main oven. Can you help?
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
370 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
