Question about Compaq Presario 700 470024-192 Notebook
HII I AM USING XP SP2 PACK.I HAVE COMPAQ NOTEBOOK.MY 2 USB PORTS ARE DEAD AS THEY DONT RESPOND TO ANY HARDWARE I CONNECT[POWER SURGE PROBLEM]  NO POWER IS DETECTED ON THESE 2 PORTS..
OK i have warranty left for 4 months but problem is no service centre nearby[nearest is 300km] so i will go for second option till i get to centre,but what is pcmcia??? where to get it?? plzz tell me few more details ....is this hardware problem???
Posted on Nov 21, 2008
    Genius:
  • Compaq Master
  • 1,252 Answers
What's the warranty status of your laptop if its under warranty take it to the servcie centre, if its not then the solution is install PCMCIA TO USB card
Posted on Nov 20, 2008
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
I frequently receive the message power surge on hub port, in dutch "Stroompiek op de hubpoort", even though when no USB device is connected. It is very annoying. What to do? computer: Compaq...
Check whether there is any metallic debris in one of your USB ports.
If there is not, then there may be some something coming into contact with the circuitry leading to the USB ports that is causing the short. If that is the case, then you'll have to take the laptop apart yourself or take it in for service.
Dec 22, 2010 | HP Compaq nx6110 PC Laptop
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Usb port not functioning
Windows XP is not compatible with USB 2.0 ports. Could you confirm you have Service pack 2 or 3 installed. If not, you should install SP2, so they should work.
Jan 12, 2009 | Toshiba Satellite A100-S8111TD Notebook
Usb ports not working
Could you tell me whether the USB ports are providing power or not.... i.e do you get any indication in your flash drive that it is getting power (a light or something)
If you are getting that then there is a problem with your windows installation. You might have to perform a clean format if there si no indiction of Power then there is a hardware problem and you might have to replae the Usb port or see the connections
Please do reply to the post and we will see if something can be done.
Dec 22, 2008 | HP Compaq nx9030 Notebook
Dead USB Ports...
Have you checked drivers not only for the usb, but for the chipset of the system itself. Also, have you installed service pack 2?
Might also just visually inspect for troublesome fingers in the ports themselves; often get bent and short out.
Good luck
Oct 16, 2007 | Compaq Presario M2000 Notebook
USB DVD ROM no detected
You need XP service pack 2 or later installed on your notebook. Does your notebook detect other USB drvices, if not your USB port on the PC is gone. If the USB prt is working and you have XP service pack 2 installed then you probably got a bum DVD drive so return it and get another.
Jul 14, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
