Question about Refrigerators
Kenmore refrigerator top-mount fridge with icemaker and water filter leaks water on right side outside fridge very intermittently, as in every other day or even once a week. it's a discrete amount of water- makes a puddle about 1 ft square. don't see water inside fridge, and water dispenser doesn't leak. model 106.76232400
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
SOURCE: kenmore refrigerator leaking at water filter
I am having the same problem, it leaks with a filter and without a filter, I even tried making it really really tight. What else could it be?
Posted on Sep 04, 2008
docjohn174
  • 943 Answers
SOURCE: model number: KSRB25FHSS05
hi .thanks for the question .is the fridge on, is it running. if not. it could be in defrost mode .if it is running .pull freezer from the wall, remove back panel ,clean all coils. thanks the appliance doc
Posted on Oct 05, 2008
rush2robby
  • 83 Answers
SOURCE: I have a Kenmore Coldspot
http://fixitnow.com/wp/2008/08/11/how-to-repair-a-leaking-evaporator-in-your-refrigerator/
go to that link and solv your problem
Posted on Nov 05, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Kitchenaide fridge icemaker is not working at all.
Check the water flow at the door.
If the water flows slowly, then you have a clogged water filter.
The filter is either outside below the doors, or in the upper right side of the refrigerator side.
Good Luck!
Jan 03, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water and Icemaker do not work
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water gets to filter but not anywhere else
your water line that goes past the filter is clogged. use compressed air to flush out
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker puts to much water
First give me the entire model # on the sticker inside the fridge so I can help you.  We can solve this one.
Oct 18, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
