FixYa.com
Tags:
Hotpoint RGB745 Gas Kitchen Range
Oven does not light (by 11 users)
posted by jj07 on Dec 08, 2006
When I turn on the oven, the display goes to PrE (preheat mode) but the oven does not heat up. The ceramic igniters are cold, there is no smell or sound of gas. I hear a relay click in the control panel when I press Start. It is also dead in Broil mode: no gas, cold igniter. The range top works properly, so there is gas and electric. I could not find a schematic. Thank you in advance for your help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
10 Other Users Have The Same Problem
Comment by ocpd426, posted on Jul 12, 2008
On my whirlpool oven when I turn on the oven part I smell gas and sometimes it doesnt lite
Comment by Guest, posted on Jul 10, 2008
oven does not work the cooktop works fine
Comment by Guest, posted on Jun 09, 2008
Brand new Thermador --Main oven does not hold the temperature that is set....turns on..and then cools down..does not stay at temperature setting.
Comment by Harlock77, posted on May 31, 2008
The burners on the stove work fine, the broier heats up ok. But the baking part of the oven does nothing
Comment by avt1889, posted on Apr 27, 2008
I have a GE Hotpoint RGB745WEA1WW with the same problem. The board lights go on, there is a click, but the oven does not heat. Burners work fine.
Best Solution
posted on Jan 04, 2007
Helpful (85)
appl1
Rank:Apprentice Apprentice
Rating: 89%, 55 votes
even if the ingitor glows, and the oven wont lite, the odds are that the ingitor is bad. it must draw 3.2 amps to open the gas valve. the only way to test the ignitor is with an amp probe.
replacing the ingnitor is about 90% a sure thing.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
ray2468
Rating: 70%, 2 votes
when i had the problem it was corrected by cleaning the connection on the gas solnoid in the back of the warming drawer
Solution #3
posted on May 05, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Mine does the same... There was smoke for a bit coming from the range for a bit and the breaker tripped. I removed the control panel and lifted the relay daughter board and seen where the burnt component is. I'm ordering a new control panel today.
Solution #4
posted on Jan 22, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
this is my model # but I have an electric oven
This Problem Also Relates To: GE Spectra JBP78 Electric Kitchen Range GE JBP71 Electric Kitchen Range GE JBP30 Electric Kitchen Range GE JBP60 Electric Kitchen Range GE JBP80 Electric Kitchen Range Bosch HDI7152 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Bosch Evolution Pro-Style 700 HDS7282U Stainless Steel Kitchen Range
Can you Help with these Kitchen Ranges problems?
HOtpoint Electric stove/oven
we just bought a used (BUT IN... Answer This...
UNEVEN HEAT IN OVEN
how do i adjust temp in oven?? Answer This...
hotpoint oven
how do i adj the temp in oven?? Answer This...
Oven not heating(magic chef
My oven takes sometime an hour... Answer This...
hotpoint oven
My hotpoint oven turns on, but... Answer This...
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 06, 2008
Same here. Spectra gas oven XL44. About 8 years old. Working just fine then for reasons unknown it just doesn't start now. Range works fine. When turning on the oven, there is no clicking sound, no firing up sound like there used to be. Nothing.
Comment by Guest, posted on Nov 10, 2007
Yep....I have the same problem with my brand new LG gas range. Burners work fine. Oven pilot glows orange but no ignition. Tech told me to check gas line. Gas line is fine. Ignitor must be bad!?
Comment by Guest, posted on Nov 09, 2007
I'm having the same problem with my Whirlpool Gold series. A tech is coming out on the 17th.
Comment by 1eng, posted on Nov 02, 2007
oven will not light. no gas smell or igniter operation noted. no fault code noted. all range top burners operating properly.
Comment by Guest, posted on Nov 01, 2007
I am having the same problem with my Spectra gas oven XL44. It is about 5 years old. It will not ignite for the oven. After many tries I did get the Broil to ignite, but not the oven.
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
