Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
My heat pump starts up in the defrost cycle.
Heat pump starts up in the defrost cycle. It runs for a long time in this mode before finnally kicking in for heat. By then the house is warmed by the heat strips and the pump is now ready to shut down. Please help, thanks.
  • 462 Answers
My question may seem a little ignorant but How do you know your heat pump starts in defrost? You can't tell by "feel". You have to measure heat with a thermometer. If its because it "feels cold" your body temp is normally 98.6'f if your heat pump is in cold air outside (say below 40 or 45'f) and its putting out 85 to 98'f air inside your home is gaining even if it feels cold to you. Hearing the reversing valve kick in or out? Just because you hear this doesn't mean its in defrost, it may normally start this way.
Now if its running for a long time? That's subject to your interpretation of long time. It could be normal too especially if the air outside is getting colder and your house is needing more heat to keep it comfortable for you. The longer the heat pump runs means the more electric it is saving you.
The one thing that makes me believe this is all normal is the fact you say the elements kick on and warm up the home before it shuts off. So heres one way to kind of tell where your at:
1 Are the filters cean?
2 When the weather warms up does the Heat pump run as long?
3 Does *** run longer as the night gets colder?
4 Does it defrost at times and you see steam coming off the out door part and the out door fan stop?
5 does it make a swishing noise just before it defrosts and maybe after it defrost?
6 does it make ice build up around the base if its been running for a few days?
7 does the air comming out the ducts test at least 5 to 8'f warmer or more, than the room temperature?
If all of these are yes then most likely you have a normal operation going on.
If the elements are coming on that usually means the heat pump cant handle the load by itself. Remember this :
It uses less electricity to run the fan motors and the compressor < 18 amps in cold weather. Typically with everything clean heating output on a 5 ton somewhere around 50,000BTUH [a 3 ton will put out around 28,000 btuh and only pull about 12 amps] you would have the indoor fan motor running any way with either of the heating systems so it isnt needed to count for effiency.
1 heating element 5KW at 240V about 20.83 Amps and it puts out only around 17,000 Btuh. But the heating element glowes red hot and consentrates heat in a shorter time thus it "feels" warmer, which it is but its not cheaper.
If this help\ed you understand your heat pump operation and you feel like it is normal now please rate me as high as you can. If you feel you you may still ahve a problem please post it and the answers to the questions above as to narrow your scope of what to look for. Thanks for using fixya and good luck.
Posted on Mar 26, 2009
Is there any danger in running my Carrier HVAC in "Emergency Heat" mode all the time?
No theirs no danger in running the Emergency Heat all the time, Emergency Heat is your backup heat mode. when the Heat Pump is not working do to a malfunction or Defrost, the Emergency Heat kicks in. The Emergency Heat is usually electric heaters so your electric bill will be much higher.
Nov 07, 2016 | Carrier Heating & Cooling
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a goodman self contained heat pump that is 3 and 1/2 years old. I wake in the night to hear what sounds like the fan runnning and running and running and air moving thru the vents. Then I will hear...
Heat pumps are a very efficient design when working properly. But lose efficiency the colder it gets outdoors. I usually tell people when it drops below freezing to turn the thermostat to aux or em. heat. A heat pump can remove heat from 20°f air. But not very well. More heat at 30°f air, obviously, and so on. So the colder it is outdoors, the longer it will operate to remove heat from outdoors. And then, if it can't keep up, it brings on the electric heat elements to compensate. Now you are running both outdoor and indoor heat. This is where it's inefficient and costly. Also, the outdoor will start to freeze up. This is normal unless you can see a substantial amount of ice. The heat pump will engage defrost mode, cycling on the electric heat indoors. And defrost mode is actually cooling mode! The reversing valve in the heat pump switches to cooling mode, cycles off the outdoor fan, and defrosts for a set time or temp. So now your electric heat is engaged, and your indoor coil is a COLD coil! Not hot! Very inefficient. These 2 things are why your elec bill is higher in the winter. So it makes sense to me, if the elec heat is going to be on anyway, to move the tstat to aux or em. heat, when it's going to be below freezing outdoors. This will turn off the heat pump and use elected heat only. The only down side to this is, if you don't have enough elec heat to keep you warm, you may need both heat pump and elec heat. So trial end error until you find what works. Also, have a qualified tech check the system for operation and efficiency. Hope this helps!
Apr 08, 2017 | Goodman PHKJ048-1 Air Conditioner
I have a aircond / heat pump unit. When in the heating mode it run for about10-15 minutes and you hear a small bang and here a rush of pressure in the aircond lines and the the unit seem to be running in...
Hello,Your heat pump is in DEFROST mode and this is normal(only during a call for heat).When in defrost mode the supply air temp should still be warm as 1st stage electric heat strip comes on during the cycle.If the unit did not defrost every once in a while the outside unit would look like a snowman after a while.The reversing valve is the "bang" when it changes over.
Oct 27, 2010 | Coleman Heating & Cooling
My amana heat pump will start and run momentarily and stop several times, and eventually it works, the house stays at 70 degrees so it works but this does not sound right what's the problem if any?
Hi; I need more info. Do You mean the outdoor unit is stoping and starting while running in a call for heat by the tstat. When heat pumps run if the temperature out side reaches low enough the outside unit will go into a defrost cycle to remove any build up of frost or ice. If the outdoor unit has a dirty coil or a low freon issue this also can trick the unit into a premature defrost cycle. Now here is another scenerio.If Your ac is running in the cool mode and stops prematurly there could be several problems. Low freon level, faulty fan motor causing the compressor to go into a freon bypass mode wich sounds very spewy. Please tell me if you are in heat mode.. Also how old is the unit. Sometimes a severly worn control contactor can disallow all the needed voltage to cross over to Your fan motor and compressor. Watch unit while its acting up... Also when unit goes into a sceduled defrost the fan will stop this is normal and will restart when the unit comes out off defrost You will here this big swoosh sound. Thats the freon being redirected back into the heating path.Let me know...alpharome416
Jan 22, 2010 | Heating & Cooling
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
149 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
