Question about Xerox Phaser 8200 Laser Printer
Please help. error report, 15,004.45:54183
Can someone help me, this codes comes on after wwarming up,
    President:
  • 2,072 Answers
There is a set of 2 Halogen lamps in the machine that heat up the drum. They are 150 watt halogens, one or both have burned out.
The way you determine it is turn the lights out in the room the machine is in and then turn on the printer. Look on the right side of the printer, there is an exaust fan vent there. Look inside for lamps glowing, I very seriously doubt they will be glowing. If not the lamps are bad, When one goes out neither will work.
If you want to attempt replacing those, let me know I can forward you some instructions.
Posted on Nov 18, 2008
  • Rick Kasper Nov 18, 2008
    Just let me know if you want the instructions. Takes about an hour and a half first time you replace them.
    Cost is less than $20, you can buy the lamps at Lowes or Home Depot. Anywhere that carries halogen lamps will do.
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
Dec 21, 2017 | Ricoh Office Equipment & Supplies
Babyran error while unpacking program code lp5
i don't have any anti-virus !!! what can i do ??
Apr 26, 2012 | Computers & Internet
I have a toshiba tecra m4-s435. i plug it in to try to use it and the charging light just blinks i got a 12311 error code off it but i cant find the code anywhere to help me with this problem. i asked...
Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
Jan 11, 2018 | Toshiba Tecra M4-S435 Tablet PC
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Error While Unpacking Program,Code 2.Please Report To Author
error while unpacking program code 2. please report to author.
Reinstall your anti-virus program. It happens when you perform Microsfot update. Remove antivirus from add/remove programs. Go to antivirus web site (scuh as pctool.com etc) and download latest antivirus and install. You will see the error is gone. Hope this help.
Nov 19, 2009 | HP Pavilion a705w PC Desktop
Yellow light on and the driver report an error code: E198 0000 What does this code mean please.
Jun 26, 2009 | Canon LASER SHOT LBP-5000 Printer
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
Error while unpacking program, code LP5.
I have the same problem "Error while unpacking program, code LP5. Please report to author"
Here is the Solution:
1. The number one solution is to disable or turn off your current anti virus for a while or every time you use that program showing "Error while unpacking program, code LP5. Please report to author." ,
  • then restart your computer,
  • open the program again which previously having error "Error while unpacking program, code LP5. Please report to author."
  • Then after using the program, you can enable or turn on the anti virus.
  • Note: If you will enable the anti virus, the error message to that program will show again; in that case, if you want to use that program again, disable the anti virus again for a while then restart your PC
  • I hope this help you very much. Thank you!
Feb 24, 2009 | Computers & Internet
Xerox Phaser 8200 Laser Printer Logo
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
