Question about Intel DG965RY Motherboard
DG965RY mother board mic recording problem
I have DG965RY mother board, the mic is not working , what should i do to work that? pls let me know the details.
  • mak fernando Dec 26, 2008
    I have a problem with the mic input. I cannot converse with anyone using "skype". Pl let me know if somebody knwos the solutions.
    Regards.
    Kusman
  • rep305 May 11, 2010
    I haven't check the web yet... does it have 5.1 or even 7.1 sound?
    What audiochipset is it using?
    If it is a realtek audio chipset (like ALC889 and so on) you might try the realtek drivers. I know that  in the majority of cases you have to use the original drivers and utilities to switch your audiosettings, because the mic-in could be used for something else instead, for example if the "soundcard" is in 5.1 or 7.1 or whatever mode.
  • 416 Answers
This MB supports 5.1 audio out. try the laest drivers & bios updates & see
http://www.intel.com/support/motherboards/desktop/dg965ry/index.htm
Posted on Jan 20, 2009
I have a DG965RY mother board can i install a 1.6 daul core on that board and download windows7 and will it work
Yes, you can install a Pentium dual core processor on this mother board. Below is a complete list of the compatible processors for this motherboard:
http://www.cpu-upgrade.com/mb-Intel/DG965RY.html
Windows 7 will also work with this motherboard. Just make sure that you install a minimum of 2GB RAM for you to take full advantage of Windows 7's Aero feature.
Mar 23, 2011 | Intel DG965RY Motherboard
I brought my intel pc on 23/07/2007, core2 duo processor& dg965ry chipset mother board. Now my system get restarted in every hour, retailer advise me to replace the motherboard, i wish to know whether...
I brought my intel pc on 03/09/2007, core2 duo processor& dg965ry chipset mother board. Now my system get is not booting and showing some EB Display on the right end corner. plz find me the Solution...
Jan 04, 2011 | Intel DG965RY Motherboard
Sir, I have Intel DG965RY Motherboard Front Panel Mic is not recognizing and i have installed Windows7 in My PC, i ahve also updated the audio drivers then it is showing latest driver is running in your...
I had the same problem.After updating the audio driver front panel was not working..
then I just un-install the driver and install the old one given in the mother board disk. And it solved the problem.
You can try it.
Oct 04, 2010 | Intel DG965RY Motherboard
I Have Intel DG965RY Mother Board. I didn't find the drivers for windows7, any one going to tell me how can i get it? if u people have any solution for this Plz Mail me my Email ID kapoorking12@gmail.com
Hey...I also have 965RY..u want video driver..just use this link and download...or copy all and paste it to address bar
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG965RY
it will work
good luck
check ur mail
Dec 17, 2009 | Intel DG965RY Motherboard
Dell latitude d600, mic works sometimes
The Mic is on the same board that the power button is on.. there is a problem with this board,, the problem is were the power button board plugs into the main board....... when you push down on the power button your affecting the mic''s conection to the main board,, {Its a bad plug}
The Mic is found next to the power button.. to the left look for a small pinhole,, ....try pushing down to the right side of that.. test Mic when you do this,,,
You need a new main [mother] board to fix
Sep 25, 2009 | Dell Latitude D600 Notebook
DG965RY mother board mic is not working
HI,
there may be problem in mic hardware. Check it on some other system. It there is no problem in hardware then it should work fine there.
Else
if there is problem in driver of mic/sound card then reinstall it. Find latest one from net. and use it.
Else
if there is problem in settings of mic. Then see volume/sound card properties/ sound card software.
there is option to test mic and also to boost it.
Boosting and noise reduction options help enhancing performance of mic.
thank you,
vijay(vote for me)
Sep 25, 2009 | Intel DG965RY Motherboard
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
Microphone on Dell Inspiron 600M PC Notebook not working
If your Inspiron 600m had a mic that you used in the past and it is no longer working, please try to press the mute/volume down/up buttons near where the whole of the mic is located.
If, after trying the above, 1 or all 3 buttons do not work, the problem is with the board that is right under the power button (small 2-3 inch length circuit board). It is not making full contact on its connector below. If you put pressure on it (just above the power button) it will all respond. I had the same problem on another 600m laptop.
Feb 23, 2009 | Dell Inspiron 600M Notebook
Mic not working
be sure that u have selected the correct input device in audio manager and u have plugged in a working mic properly...
if its still not working open ur input manager of ur audio device and select the input mode over der to a normal 1 not 5.1 channel then mic would work
Aug 31, 2008 | Intel DG965RY Motherboard
MicroPhone Not working
Download the latest audio driver from intel site. Install it, ur mic will start working.....
Folloe the link and select Sigmatel audio driver
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2374&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#DRV
Nov 19, 2007 | Intel DG965RY Motherboard
Intel DG965RY Motherboard Logo
368 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
