Question about Kenmore 62602 Electric Dryer
Can't remove back of Kenmore 66901
I'm very inexperienced in repairing a dryer and no real electrica knowledge. I've printed a great deal of help for my main problem whick is, the drum turns, but, no heat. I've had dryer for years. It has been a very good dryer. I'm trying to fined fuses, thermostat...etc. The back of the dryer has screws which I removed, but the back seems to be welded on in specific spots and won't come off. Any help would be greatly appreciated as I can't call a tech at this time. Thanks. Rear panel door appears to be welded and can't remove.
    Genius:
  • 1,028 Answers
Believe that model has lower front panel remove it ..clips each side top edge press them down pull panel off ..element ,fuses thermostat behind it
Posted on Nov 19, 2008
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Switching a kenmore dryer door from right to left. I have taken off the door.. but it looks like I need to remove the plastic covering on the door to remove the hinge and install on the other side. There...
In General the deconstruction of the door is not needed. With a great deal of Kenmore dryers you can simply turn the door 180 degrees and reinstall it.
Aug 24, 2011 | Kenmore 85871 Electric Dryer
Mi secadora electrica oasis kenmore elite aparece un codigo PF que significa eso como puedo resolverlo
PF means power Failure unplug hold the cancel button for 3-5 seconds if the pf doesnt disappear then unplug the unit for 7 minutes this will make the control reset on the board if the pf still doesnt fade then you would have a control issue and most likely have to replace the control or call a technician if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Feb 26, 2011 | Kenmore Elite Oasis 6809 Electric Dryer
Loud sqeeking noise and i can turn drum both ways is that normal?
Thank you for contacting Fixya.com.
Please check this link to have an in-depth knowledge related to your issue:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itsnoisy_electric
Please get back to us if you have any further query.
Have a nice day.
Nov 30, 2010 | Kenmore 72062 Gas Dryer
My gas dryer is getting heat. But is not turning around
Please check the bellow link to have an in-depth knowledge related to your issue:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itwonttumble_electric
Nov 30, 2010 | Kenmore Dryers
Kenmore 600 timer no longer works
This is not an easy task. you will need to disassemble the entire control panel to extract the bad or faulty timer. Extraction can be tough on some model. this will cause an inexperienced do it yourselfer to break off fragile retaining clips and screw anchors as well. you will also need to make sure that the wiring harness is re attached to the new replacement timer correctly. this is important. We recommend calling for service on all electrical repairs if you have minimal experience in this field of repair. Unfortunately , when these timers are damaged, you cannot repair them. you will need to replace the bad timer with a entirely new timer.
Jun 10, 2009 | Kenmore 600 6963 Electric Dryer
Go to YouTube and search for "Kenmore Dryer Repair" There is a guy that has posted over 22 "2 minute" video's on how to disassemble and troubleshoot dryer problems, he is fantastic and should be able to figure out what is wrong by watching his videos.
Nov 16, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
