Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
How many tools will operate at same time
Need to know how many roofing guns and how many framing guns can run at the same time using a Hitachi ec 12 4 gallon compressor?
    Scholar:
  • 65 Answers
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Posted on Nov 20, 2008
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
I have an old Hitachi Framing Gun (bout 15 years old) Needs a repair kit. I could not find any serial numbers except C315814D and C315808. On two lableas that a are prtetty beat up - only the se numbers...
I know of only one company that has a complete kit but they are located in the Cincinnati, OH area. They would need to know if this is a coil nailer/roofing nailer and some other info but these kits unless you can find an air tool repair center in your area are complete, I have used them for 6 years and they should take care of your problem. Their site if you want to view it is Nailgundepot.com and they have another link. Let me know if you need more assistance. The kit lists for around 12.00
Jan 03, 2010 | Hitachi Air Tools & Compressors
Do I need to oil this gun during use? I have many other guns that require oiling and have a stamp on the gun that says do, tho I do have another senco trim gun that I know is oilless. Do I need to oil the...
yes, squirt oil in the tool 2 times daily depending on use. do not oil the nails/pawl area, it only collects dirt. About 6 drops in the air fitting should be fine.
Nov 13, 2009 | Senco Air Tools & Compressors
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Need to know size nail that it shoots and do you have new lables for the gun
This gun takes 2"-3 1/4" .113" - .131" Paper striped 34 degree clipped head nails.
This is the Tool Card provided by Hitachi. Follow link:
http://www.hitachipowertools.com/product/files/pneumatics/framing_nailers/NR83AA3toolcard.pdf
Sep 07, 2009 | Hitachi NR83AA3 3 1/4" Clipped Head...
My brand new hitachi NV45AB2 roofing nailer leaks air through the trigger when it is half depressed. I purchased one and returned it only to find the new one I recieved to replace it does the same thing....
Take off the back cover and make sure it's not too dry inside. Spray the inside with some WD40. You can take off the top cover. Pop the piston, cylinder, and head valve out, making sure all the seals and rings are seated correctly.Sounds like the piston is momentarily sticking. Does it shoot at all? Lemme know. Please rate me
Jun 03, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
237 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
