Question about Whirlpool Duet GHW9150P Front Load Washer
FH Errors what would cause this. we have cleaned all the filters,hoses,etc....
  • 41 Answers
FH error code has to do with no water detected or pressure switch trip not detected. is there water in the unit or is it empty? Joe
Posted on Nov 18, 2008
How to fix fh error that started with F02?
boil some water an put in some ammonia an toss it in an run it on sanitize at hottest an longest cycle.
open the filter again when completed an look inside an up in the boot area an in the motor area to see its all cleaned .
in the future use only he detergent
an use vinegar for softener for your clothing.
if you have gunk its from the softner your previously using it will need as many cleanings as it takes to clear it.
if too much work then take the whole unit to the yard an pressure wash it all out.
hope it helps .
Jun 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
FH error on display
An FH error usually means low water flow into the washer. This can be caused by debris in the filters between the intake hoses and the washer, closed water valves, low water pressure or a problem with the system that checks the water flow.
Some intake hoses when they detect a leak will seal themselves. So you may want to replace them. Shut off the water valves and remove the hoses from the washer. Check the filters for debris. With a bucket under the hoses, open the valves and check the rate of water flow. You may want to check the filters on the valve side of the intake hoses after turning the valves to off again. If water flows into the washer and then into the drain, reset the drain hose. The outlet of the hose should be above the water level in the washer. Otherwise, the water will suction out of the unit.
If these parts are fine and there is still no water flowing into the machine, the intake valve is faulty.
If you are getting the error when the washer is full of water, it's the pressure switch or the flow meter. In a few cases, the cause is actually damage to the air hoses connected to the pressure switch. If one of these thin tubes is leaking, the pressure switch will not work properly.
I hope this helps.
Dec 12, 2012 | Kenmore Elite 45986 Front Load Washer
Whirlpool ghw9150pwo flashes FH
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Oct 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps flashing up fh and not working
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The initials FH keeeps comin up on screen when the wash is at 26 minutes Then I have to turn off power and press start button again. What do these initials stand for?
GENE
Sep 12, 2011 | Whirlpool AWM6100 Front Load Washer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool awm 8103/s keeps stopping during cycle with code FH displayed? any suggestions
Whirlpool's 'FH' stands for 'no water inlet' (but goodness knows how 'FH' could mean that!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 04, 2011 | Washing Machines
Stops in middle of programme and FH keeps comin up
Indesit (Hotpoint, Ariston) 'FH' stands for ' no water inlet'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call to check whether it is the valve or the control board causing the problem;-0(
John C
Jun 18, 2011 | Whirlpool Washing Machines
FH error - how to clean water inlet screen?
open the top of the machine and check the hoses to the pressure switch
looks like this
http://store.4appliancerepairparts.com/servlet/-strse-6581/134438301-Water-Level-Pressure/Detail
Nov 12, 2007 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
574 people viewed this question
Dan Webster
Dan Webster
Sal De
