Question about Medion MD-40954 Notebook
One side keys are not responding.-gh/ appearing if press any key
One side keys are not responding.If i press any key of the other side the following characters are appearing.they are -gh/.
  • Medion Master
  • 19,396 Answers
That sounds like a faulty keyboard.
Probably you already fixed the problem, but if you need Medion spares call medion, they can supply parts and tell you what parts are compatible:Medion.com
Try also Computer parts for MEDION
In US you can also contact Quanta that distributes medion parts internationally, they are locaed in US and ask part price and availability: Contact Us
Posted on May 17, 2009
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
My sharp AL - 1457D its not responding it only blinks 4
Hi, there is no error 4 alone it is usually followed by a H that is H4. Try to key in the following C Auto C Auto then enter 14 and press Copy key. If it was power low voltage , it will not re-appear but if it comes back then replace heater lamp and reset again.
Jan 17, 2011 | Sharp AL-1457 Black and White Copier
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
Hello, I bought a brother all in one printer, the MFC-J265. It is hooked up to the computer and I have installed it the way it says in the manual, except when the printer is on there is nothing shown on...
f the keys on the control panel do not respond or triple beep when youpress them follow the steps listed below:1. Unplug your machine from the electrical outlet, wait 30 seconds and then plug it back in.
2. Verify the date and time are displayed on the LCD.
a.If the date and time show on the display, continue to step 3.
b. If the LCD displays an error message (example: paper jam) or status message (example: ink empty), refer to the necessary solution for the message that is appearing on the LCD.
c.f the display is blank, verify the power cord is connected. If the power cord is connected to a surge protector or power switch, remove thecord from the device and connect it directly to the outlet. Next, verifythe unit is powered ON. The MFC has an ON/OFF key located on the right side of the unit. In OFF mode the display will be blank. If the display is still blank, try a different known working electrical outlet at your location. If the display still remains blank and your machine iswithin warranty, you can locate a Brother Authorized Service Center (ASC) in your area using one of the following:
Click on:
http://www.brother-usa.com/support/and then click on the "Service Center Locator" option located on the left side of the page or for automated assistance by telephone, dial 1-800-284-4357 and select Option2 to access our fax back system. This system can provide you a printed list via facsimile or verbal listings of a Brother ASC in your area. Youmay also contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays. If you are outof warranty, you need to contact a Brother Authorized Service Center using the information listed above.
3. There are 3 Mode keys located below the LCD display, PHOTOCAPTURE, FAX, SCAN and COPY. The correct mode key must be illuminated in green when attempting to access or program one of these functions (faxing, copying or scanning). Examples: If you try to access the "Setup Receive"or "Setup Send" menu's, make sure the FAX mode key is illuminated in green. If not, press it to turn Fax Mode "ON". If you are trying to make a copy, make sure the COPY mode key is illuminated in green. If not, press it to turn the COPY mode "ON". If the correct mode key is notilluminated in green when attempting to access specific functions, the keys on the control will triple beep when pressed.
4. Press the keys to see if they respond. For example: if you press the MENU/SET key the menu options should be displayed on the LCD. If you press the HOOK key, you should hear a dial tone (provided the speaker volume is set at an audible level, and the line connections are correct).
5. If every key still triple beeps or does not respond, gently massage each key on the control panel in a circular motion to dislodge any stuckkeys. You should do this regardless of whether or not any of the keys appear to be stuck. Then test the functionality of the control panel again, using either the MENU/SET or HOOK key, as outlined in STEP 4.
If none of the keys are stuck, or if freeing a stuck key did not restorethe control panel#s functionality and your machine is within warranty, you can locate a Brother Authorized Service Center (ASC) in your area using one of the following:
Click on:
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | Brother MFC 210C All-In-One InkJet Printer
Black screen with white arrow
Step 1: Opening a command promptThis error prevents Windows XP from opening. This problem has to be addressed from a command prompt environment. Use the following steps to open a command prompt environment:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears.The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
    NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CD's, press the R key to open the Recovery Console.
    NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the log in prompt appears, press the number next to the windows version (min int or Windows) and type the log on password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: disk part
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a disk part prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folderUse the following steps to find and replace the L sass file from the command prompt environment:
  1. Type the following at the command prompt: CD X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd c:\i386
    • cd c:\Windows\i386
  3. Press the Enter key, and type the following at the command prompt: expand lsass.ex_ X:\windows\system32 (where X is the drive letter)
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib lsass.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename lsass.exe lsass.bak
  7. Press the Enter key, and type the following at the command prompt: rename lsass.ex_ lsass.exe
  8. Press the Enter key, and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, go to the next step.
Step 3: Recovering the PC If the error still continues, recover the PC .
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 11, 2010 | Dell Inspiron 530s Desktop Computer
Memory is full
Please follow this instructions; i don't know whether you've disconnected or not but it's been disconnected from my side. So i just wanna give some more hints to fix your problem;
Press the Menu key on the control panel.
Press the Up or Down Arrow key until Fax appears on the LCD.
Then, press OK.
Press the Up or Down Arrow key until Remote Fax Opt or
Advanced Fax Operation appears and press OK.
Press the Up or Down Arrow key until Fwd/Page/Store or
Forward/Store appears and press OK.
Press the Up or Down Arrow key until Off appears and press OK.
If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Or
If you would like to reprint the saved faxes, press 2 (No), press
Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
Press the Menu key.
Then, press OK.
Press the Up or Down Arrow key until Print Fax or Print Document appears and press OK.
Press Black(Mono) Start.
After printing is finished, press Stop/Exit.
Good luck. Thanks for using FixYa.
Jun 01, 2010 | Brother MFC-5460CN All-In-One InkJet...
Cannot dial out/press any key
check all the side key, try unscrew the phone, remove the all side key and paste the side key wel
Dec 22, 2008 | Samsung SYNC SGH-A707 Cellular Phone
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Keyboard problem
Do the following steps:
  1. Press and Hold Fn then Press Numlock/Scroll lock, if it works then good.
  2. otherwise Press and Hold Shift Key then Press Numlock/Scroll lock.
If still problem just Ask me
Thanks
Iqbal
Apr 12, 2008 | IBM ThinkPad T30 2366 Notebook
Medion MD-40954 Notebook Logo
219 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
