Question about Nikon FG 35mm SLR Camera
Nikon FG shutter
I was prepairing to use my FG, checking it out, shot on picture and the shutter stayed up, I put new batteries in, twice just in case they were bad, but the shutter stayed up.
  • Nikon Expert
  • 362 Answers
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
Posted on Nov 20, 2008
Subject: Nikon FG mirror is in the up position?
I recently pulled a Nikon FG out of the closet and tried cranking the film advance lever and pressing the shutter button there wasn't a action, however it did not want to crank. Then I realized the battery may be dead so I replaced it with two 1.5 batteries since the 3 volt was dead and Walla the crank worked right away and was able to hear a click. I am assuming it took a picture however, the mirror is in the up position, I check to see if your camera has a feature that allows locking the mirror in the up position but there is none on the Nikon FG nor is there a T or B button setting either. Please help me resolve this issue obviously the item does not need repair it just a simple know how issue and I don't know how to fix the mirror is in the up position, since I am a newby to SLR film camera:)? Please help!!!!!!!!!
Posted on Feb 20, 2009
My nikon fg shutter is stuck but only works when set on m90 or b
Sounds like you got dead batteries. Try putting in a fresh set.
Dec 26, 2013 | Nikon FG 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Nikon FG 35mm
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on
Mar 18, 2008 | Cameras
Nikon fg light meter
Ah, I figured this out. It's not the battery, since the light isn't dimmed. I had the same problem with the light being stuck at 60/120, and it was just flashing. There's a certain mechanism in the camera that only allows the light meter to start working when the exposure count is at 1. So when you load your film, you have to take 2 or 3 exposures, and crank it, before the light meter kicks in.
Oct 27, 2007 | Nikon FG 35mm SLR Camera
Cleaning out dirt and dust inside nikon fg camera
FG's are pretty tough old cameras. You can use a cloth and a lenspen brush, but be very careful of the shutter curtain...its delicate and if you damage it you might as well get another FG ($30 or so on Ebay). My first Nikon was an FG-20...still works like new.
Oct 25, 2007 | Cameras
Nikon FG 35mm SLR Camera Logo
697 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
