Question about Maytag Neptune MDE5500AY Electric Dryer
  • 41 Answers
Your thumpin noise is most likely a flat spot on your drum rollers. open the door and remove the 4 screws ( 2 on either side ). this will allow you to take the front panel off. after that is removed, there are 4 3/8 nut screws that hold on the front bulkhead. remove those screws and lift up on the bulkhead to remove ( note: you may need to remove the 2 nuts screws and brackets that secure the top so you can lift the top up ). after removing the bulkhead, you will need to undo the belt ( easiest if you do it from the back ) and take out the drum. your drum rollers are on the back of the dryer on the bottom. you can visually inspect them and if they are bad, they will need to be replaced. Joe
Posted on Nov 18, 2008
There is a loud thumping noise when the driver is working It is still drying the clothes
The drum turns on a track in the front area, it is turning on two wheels in the back side. Probably one of the wheels has bad bearings and isn't supporting well, flopping around. Assuming this is electrical type, just have someone remove a panel in the back to see if that's it.
Jun 03, 2016 | Dryers
Drum flopping around and making clunking noise
Almost certainty that the bearings are faulty, major problem usually no worth repair fault is caused by overloading the machine
Nov 23, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
Bosch wfk 2800 drum makes a noise when turned around
When you rotate the drum by hand slowly does it feel bumpy and still make a noise? If so suspect the bearings on the drum to be the culprit. Hope this helps.
Nov 17, 2013 | Washing Machines
I have an LG gas dryer it has black sticky pads stuck to the drum. one of them came loose and was flopping around inside the dryer and even went around the idler pulley. I can remove the material from the...
It just help the drum does not make noise if it touches to the cover when the drum has heavy load. You can clean it up and forget about it.
Sep 04, 2013 | LG Dryers
The inside drum quit turning. is there a belt that turns this and if so how do I get to it. I had the top open but could not see anything. The drum spins if I manually spin it so I know it is not bound up...
if you cant see a belt about 1/4" wide around the drum, there will be a mark where the belt was on the drum before it broke,remove front panel and restring belt around the drum,then replace front drum piece that holds the drum in place and then string belt around idler and motor pulleys and replace front cover
Mar 23, 2011 | Maytag PYE2300AY Electric Dryer
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
