Question about HP PSC 1350 All-In-One Thermal Printer
Psc 1350 all-in-one
Every time I go to print the stop printer indicator comes up. I have checked all connections and paper feeds in printer. I think it may be involved with the driver or other contact with my computer (e-Mac). I don't know where to look. I went to the utility but it won't come up for me to use it. My other computers can print with this printer. My computer works fine except for this particular problem. Thanks, Herb Baker
  • 62 Answers
Try using it on one computer only, then u wil know if there is a network problem.
Posted on Jul 11, 2007
On my psc 1350 when I hit print or copy the paper will feed in ok but the page comes out blank. The check ink cartridge light does not come on ?
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 09, 2011 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP 1350 all-in-one ran out of paper.
Every time this device runs out of paper, it's a hassle. I powered off the pc and the printer, and then moved the usb cable to another usb port. Power on the printer and after it has gone thru its startup, power on the computer. Then the jobs in the queue printed just fine.
Apr 14, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
May 16, 2008 | HP PSC 1350v All-In-One InkJet Printer
HP PSC 1350
Try cleaning your printer and its rubber rollers. Also make sure there is no object stuck inside the printer that prevents the printer from loading the paper smoothly. may be you have no other problem.
Oct 24, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
55 people viewed this question
Clive
Clive
