Question about RCA P52926 52" Rear Projection Television
56 projection t.v. color problems
I have a RCA 56 inch projection t.v. and i got it from a friend. The picture comes in fine but the colors (red, yellow, blue) are visible. Even when there is no picture and the screen is fuzzy the colors are still there.
    President:
  • 3,130 Answers
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Posted on Dec 08, 2006
  • 65 Answers
If this tv exhibits signs of colors separating ie when inputs are black screen and menu comes up then this tv has a convergence issue there are no stk packs in any ctc chassis made by rca the power supply board is mounted in the middle of the tv right behind the crts it has a red panduit connector on it if you unplug the power connector to this board and find that your convergence problem hasnt change then the board is no longer providing correction voltage to the convergenece pcb last i looked the redigned sub for the converge power supply pcb was available with an rca number lets face it the rca boxes have pictures of dogs on them
Posted on Dec 09, 2006
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
56 inch projection tv
This is a convergence problem. If you would please post the make and model, I can provide you with some details about the probable defective parts etc.
Thanks,
Dan
Sep 08, 2008 | Akai Televison & Video
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA 56" Rear Projection Television
Not sure if you have the same problem I have but my colors are all off too.  I have a 52" projection and from calling RCA with my problem (colors off & have shadows) they said all projection tv's color need to be adjusted every so often (which they do not tell you) after purchasing this tv for $1000.00 13 mos ago I have the same problem.  It will be approx. 500.00 to fix the problem and I got no where with the RCA 800 number.  A friend of mine had the same problem so I am sure its the same.  Good Luck!
Oct 21, 2007 | RCA HD52W59 HDTV Projection Television
RCA P52926 52" Rear Projection Television Logo
522 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
