Question about RCA HD50LPW164 50" Rear Projection HDTV
RCA HD50LPW164 PWR LED 10 short and 1 long blink and restarts
TV turns on normal with good pictue ans sound. With in a minute the sound stops and the picture freezes. The Power Blue LED blinks 10 times fast /blink per second/ and one time long /LED stay on for 4-5 seconds/, than the LED turns off. The TV restarts at this point and the same cycle repetes again and again.
It is not overheating problem /thermostat/ and all fans are runing.
What 10 short and 1 long blink LED code means?
  • 1030 Answers
SOURCE: rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Posted on Dec 07, 2007
  • 5138 Answers
you have a bad capacitor around flybackor neer by transformer.
Posted on Jan 17, 2008
  • 8617 Answers
SOURCE: binks 5 times
You need to replace the capacitors on the power board. this is a very common problem with the RCA dlps See my tip under my profile for the ATC336 chassis RCA, your model is the ATC311 but it applies to your model as well.
Posted on Aug 06, 2008
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
  • 131 Answers
SOURCE: I have an RCA DLP M50WH72S tv. Powers up, picture
Hello; I am John at J D Electronics in Poland Maine. I have had an RCA model M50WH72S setting dead in my shop for over a year now and is now mine. The set would start intermittently and run for an hour and die. Other times it would not start at all and the LED would flash 5 or 6 times and stop. With no support from Thomson/ RCA, I was on my own. The extended warranty Co said to try the light engine first. I replaced the light engine with no improvement, just the led flashing. I was not going to pay 500 to 700 dollars for other boards to try to fix this piece of JUNK.I have since read several blogs that point to power supply caps as being the problem. I took this piece of junk apart for the last time before I hauled it to the dump. I pulled out the power supply on the left as you face the back of set. I noticed 2 Electrolytic caps had " domed shaped tops ,which is a good sign of failure or overheating. They are 1000 ufd @ 35Volts 105 degree rating. They were both bad along with 2 more on the same board ! They are labeled CP624 and CP647 on the bottom edge of the board inside the "c" shaped heat sink. The other two are above the chopper transformer labeled CP641 @ CP639. replacing these fixed the set. Call DigiKey 800-344-4539 part # 493-1588 are ten for $7.00. Don't spend money on a lamp you don't need.
Posted on Jan 10, 2010
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Rca model m61wh74syx1 is turning on with no pitcure and blinking 5 times then trying to restart
Hi,If your tv is around 1-2 yrs and haven't replaced the lamp it might be time to replace it.But if you hear clicking or continually trying to restart it could be your ballast ,which is the board that powers the lamp.The lamp you will need is the 270414 Found the lam pyou need here: Good luck and God bless you!
Jan 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Sep 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
78 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
