Cd spins buts doesn't play I fixed the drawer open closing
I place the cd in the drawer, it closes, understands that it has a disc, but it just spins and doesn't read the cd
    New Friend:
  • 35 Answers
Clean the lens of the laser with a cotton swab. Remove the cover, and locate the glass lens at the top of the laser assembly. Pre-wet a cotton swab with glass cleaner and wipe the lens carefully without applying pressure. Use the other end of the swab to dry off and remove any residual dust or gunk.
Reassemble the unit and load a disc. If the problem was caused by dust or smog film on the lens, it should now play without any problem.
Posted on Mar 02, 2009
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
CD DISC IS NOT SPINNING
Check the cd drawer sometimes the position switch is not detecting the drawer completely closed.
It could be an obstructing object stuck behind the drawer door who prevent the drawer to close completely.
Spider Guy
Jan 11, 2010 | Audio Players & Recorders
NAD C521 CD Player It will not play my CDs. The CD drawer closes normally with CD in place but after a pause, the drawer opens again. There is no 'no disk' warning. The 'no disk' warning does appear...
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Sep 07, 2009 | NAD C521 CD Player
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Ps2 Not spinning disc
ok you hav ridep a motor ribben replase and it should work
Nov 27, 2008 | Sony PlayStation 2 Slimline Console
Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Mar 03, 2008 | Audio Players & Recorders
Does not spin the disc, therefore cannot read it.
Form the sound of it there is a problem with your motor. Does the unit make any noise after you insert a disc? You should hear a clicking, which is the laser adjusting, and a whir, of the motor spinning. If you do hear the motor you may be able to fix it, if you dont, it is probably toast, and you will have to replace the drive.
Feb 08, 2008 | Pioneer DVR 105 DVD-RW Burner
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
418 people viewed this question
 Grubhead
Grubhead
