Question about Sony Cyber-shot DSC-H2 Digital Camera
Camera keeps shutting off.
2 year old carmera, never replaced the Sony rechargeable batteries(AA)(NiMH). Bought new rechargeable batteries (Rayovac)(NiMH), and camera still registers no battery life and shuts off. Do I need the Sony Cybershot Batteries, or what could the problem be?
  • 2 more comments
  • jschafer12 Nov 18, 2008
    I will try that. Why are "Sony" NiMH batteries different that other NiMH batteries such as Energizer, Rayovac, etc...just curious on why the Sony ones will work and the other ones won't. Thanks very much.
  • Anonymous Dec 01, 2008
    I had the same problem but I was using the sony batteries and was just a year old and so I sent it in to sony and the CTD or CCD, Board, LCD Module. was replaced...
  • jschafer12 Dec 05, 2008
    TRIED THE BATTERIES, BUT THAT DIDN'T WORK
  • jenclark Dec 21, 2008
    Thanks so much for the answer to this! I had the same problem and took it to a shop and they said it was going to cost up to $250 to fix it! Its weird though, I have used Energizer batteries when the charge ran out on my Sonys without a problem before. I am going out today and buying a second set of the Sony's as my spare now! I thought my camera was a goner! Thanks again!
  • 10,594 Answers
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
  • Shahid Electronics
    Shahid Electronics Nov 18, 2008
    Sony Cyber-shot batteries have more current then other batteries. Normally it has 2500 MA or more.
When I put completely new batteries in, it keeps saying "battery empty" in the window? Have tried several new batteries and is refusing all of them?
You could try using 2 x AA NiMH rechargeable battery or2 x AA NiCd rechargeable batteries if you just using ordinary AA batteries at the moment......
May 01, 2014 | Olympus Camedia C-480 Zoom Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Choosing batteries
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Sony Cyber-shot DSC-H2 Digital Camera Logo
338 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
