Question about Olympus Camedia C-725 Digital Camera
Sticky Zoom Control
Once my camera warms up, the zoom control becomes sticky. After moving this control to the right or left, it should immediately move back to the centre position once released. It moves back too slowly resulting in the lens continuing to move in or out. In addition, the shutter button (part of the same control) sometimes sticks. I assume that something was spilled into the control at some time. I've removed the screws releasing the control but there is nothing obviously wrong to the naked eye. Before I take it in for a potentially costly repair, is there anything I can spray in the mechanism that may clear the problem but not harm the circuitry? Thanks in advance. Clark Martin
  • Clark Martin Dec 14, 2006
    I was able to find a solution to my problem on newsgroup 'rec.photo.digital'. I'm posting it here for any who may have a similar problem.
    Shut off camera and remove batteries.
    Remove the two screws holding the zoom/shutter control in place. Remove the control being careful not to pull on the small ribbon cable. Cover the camera cavity to prevent anything from falling inside. Lightly spray the top and bottom of the control with Isopropyl Alcohol. (I used a 99% pure solution). Now squeeze a length of Dental Floss (I used the waxed stuff) under the zoom control - top-side of the control. Loop it around under the control and move it back and forth a few times. Remove the floss. In my case, there was visible black grunge on the floss, no doubt the sticky substance causing the problem. Spray in more alcohol. Using a can of compressed air, dry the entire control as much as possible. The air pressure may force out more contamination. Let it sit for several hours to assure it's thoroughly dry. Reassemble. Voila! Problem solved.
    Clark Martin
  • Clark Martin Dec 28, 2006
    Clark Martin
  • 114 Answers
Just use alcohol on the button and move it around to all the positions it goes do that for some times.
Posted on Jan 19, 2007
I have a Cannon Powershot S5IS and the zoom leveler button (around the shutter button) is sticky. If not used for a long time it will be sticky and will also get sticky if in warm weather outside or in the...
Take your camera to a Canon authorized service center and see if they can try to clean the button area. This might solve your issue. Other than a cleaning they will most likely have to replace the button assembly and/or top cover depending on how the camera is designed.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon Cameras
My camera wont take pictures or zoom. but will do everything else?
hi would you give more detail? what is the name of camera model. how is shutter release and zoom switch like--stiff, sticky, normal? Thanks and best regard!
May 22, 2011 | Cameras
Turn on the unit and goes to full zoom. Back it off manually, it will immediately return to full zoom. Unit was bought new about 6 years ago.
My camera did the same....it turned out to be a sticking zoom switch. With the camera turned OFF... move the zoom button ON TOP ( above the view finder) of the camera to the left and right about 20 or 30 times... then turn the camera on and try it.... very simple... but it worked for me :o)
Gazza
Dec 04, 2010 | JVC GR-DX307 Mini DV Digital Camcorder
Sticky zoom control
Put some WD-40 on a cotton swab, squeeze the tip and let it drizzle down into the zoom switch.
Apr 15, 2010 | Samsung HZ10W / WB500 Digital Camera
My zoom is sticky
You can use rubbing alcohol and cotton swab and clean it.
Jun 23, 2009 | Quasar VM-D51 Camcorder
Sticky buttons on my xias camera
Remove the screws from the camera, than slowly pull apart the camera, remove the buttons and you can take a cotton swab and rubbing alcohol and clean around the buttons.
Jun 02, 2009 | Norcent Technologies Xias DCS-760 Digital...
Zoom button
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera.
You can replace upper part of camera with following part number..
A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part.
Part available in Parts Store for $24
Feb 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sticky zoom button
I put some isopropyl alcohol on a cotton swab and gently cleaned the area around the zoom button, and now it moves freely.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Canon MVX250i Zoom
found the solution somewhere else on the net: just leave the camera lying with the batterie taken out for a while and it works again
Jan 01, 2008 | Canon MVX250I Mini DV Digital Camcorder
Olympus Camedia C-725 Digital Camera Logo
138 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
