I have a dell inspiron 700m laptop...when I click onto internet explorer I get the message internet explorer (not responding) and the inter net never uploads....
  • gail 857 Nov 18, 2008
    I went to start and clicked on control panel...nothing happened...However, later This is what came across the screen Windows connot find '(null)' . Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click OK.
  • gail 857 Nov 20, 2008
    I tried the suggested solution to no avail. Now I get windows Internet explorer (not responding)...
    Brigadier General:
  • 6,966 Answers
May I offer a different perspective, it is possible that your computer is infected with a virus and/or a malicious program. Before trying out any and all re-installation, pls try to:
  • do a Disk Cleanup (Start/ All Programs, Accessories, System Tools). Check all boxes;
  • run your antivirus;
  • download, install and run Ad-Aware;
  • do everything again in Safe Mode. Reboot, press F8 before Windows starts;
  • Press Windows key + R, type "msconfig" less the quotes; goto Startup tab, un-check everything that you feel is unnecessary such as monitor, updates, and others.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 20, 2008
    Sergeant:
  • 229 Answers
I hate to state the obvious but have you subscribed to an internet provider? It is required to have one in order to connect to the internet. Furthermore laptops require that you hook up through your phone(wireless or landline) are you doing so? You can also now get wireless broadband "modems". Be sure you have this before you mess with all the connectivity issues. Hope this helps.
  • 728 Answers
Check the connection of the internet cable and make sure it does not have a short or is not broken and that you have it plugged up to the right area. Then unplug it and restart your computer. Then plug it up and see if it lets you get on that time.
    Genius:
  • 1,605 Answers
Dell 700m laptop has 512MB or memories and 40GB of hard drive.
the reason that you are having problem is the memories is working over time, because of all of the Internet Temporary files and cookies taken pu all of the available hard drive space.
512MB for a 2.8Gz machine is not a ideal setup. you need to upgrade the meories to 1GB at minimum.
in the mean time right click on internet explorer>> properties or control panel Internet>> open.click on deleted under the browsing history, click on delete all, and check the "also delete files and settings stored by add-ons", click yes and OK.
Don't worry! ths is only deleting all of the Internet Temporary files. and cookies. it will not affact what you have stored.
that should at least let you get on the Internet.
Posted on Nov 18, 2008
  • 1,879 Answers
Try this :
Click Start then Run, in the small box that'll pop-up, type the whole address : http://www.firefox.com and hit ok.
Do the same step above and go to http://www.microsoft.com and install IE 8
  • monk3ybidzness
    monk3ybidzness Nov 20, 2008
    "clicked on Control Panel...nothing happened" - you got a serious Windows problem.
    Since you can't access Control Panel, follow the following steps to do a System Restore, try to remember the last time your computer worked fine and go back to that date.
    To start System Restore using the Command prompt, follow these steps:
    1. Restart your computer, and then press and hold F8 during the initial
      startup to start your computer in safe mode with a Command prompt.
    2. Use the arrow keys to select the Safe mode with a Command prompt option.
    3. If you are prompted to select an operating system, use the arrow keys
      to select the appropriate operating system for your computer, and then
      press ENTER.
    4. Log on as an administrator or with an account that has administrator credentials.
    5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER. ( %systemroot% = your local drive, usually C: )
    6. Follow the instructions that appear on the screen to restore your computer to a functional state.
    President:
  • 1,952 Answers
Remove the previous software and reinstall software again and try...
else
goto this site and download
http://www.microsoft.com/windows/ie/downloads/critical/ie6sp1/default.mspx
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Nov 18, 2008
    delete the previous thro control panel and reinstall it
    mohammed marika thambi Nov 19, 2008
    hey goto control panel...then select add or remove icon...find ur ie software and then uninstall tat...then u again reinstall with the help of my link
    Click start and type "Internet Explorer" and one of the options will be to
    run with no addons. Try this mode to see if it runs ok. If so, then the
    problem lies in a plugin being used and loaded by IE when it initializes.
    Under Internet Options/Programs tab in the Control Panel, there is a "manage
    addons" button. Click it and begin disabling unnecessary plugins that load
    with IE.
    mohammed marika thambi Nov 20, 2008
    Go to Tools > Internet Options > Security > Custom Level
    Now scroll down to the Downloads section. Enable "Automatic prompting
    for file downloads". Enable "File download". Click "OK" and apply the
    changes.
  • 4,806 Answers
One of the add-ons is causing the IE not to respond, you can start internet explorer without odd-ons, try this, if it works and you get the connection try to re-install add-ons like java and macromedia flash or why not try google chrome, this is blisteringly fast and i think you would enjoy what is does.
Also check all the programmes and drivers have all booted up before you try to connect to the internet as IE is a memory hungry app!
please keep us informed of your progress in case we have to help you further
good luck and kind regards
  • Lee Hodgson
    Lee Hodgson Nov 20, 2008
    go to this site:
    http://www.microsoft.com/downloads/Searc...
    download the IE you want and put it on a memory stick/flash drive
    copy the file to your computer.
    uninstall the IE in contol panel, programmes and features in vista. reboot the pc and clean the registry, if you don't have a registry cleaner, download CCleaner
    then install then IE that you copied to the pc
    hopefully this will work
    regards
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Which OS(operating System) is using. For ex. Windows vista, Windows XP etc.... Please let me know. Also update the internet exploxer. Try to Update the OS.
Also There is a Vista Home Premium machine which IE crashes frequently.
This issue may be caused by some 3rd party add-ons. As a result, please reset the IE settings to disable add-ons:
1. Close any IE or Windows Explorer windows that are currently open.
2. Open a new IE window.
3. Click the Tools button, and then click Internet Options.
4. Click the Advanced tab, and then click Reset.
5. In the Reset Internet Explorer Settings dialog box, click Reset.
6. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
7. Close IE. (The changes will take effect the next time you open IE.)
After that, please open IE again to verify if the issue has been resloved.
Thanks
good luck
  • 541 Answers
Go in to control panel then go to network connections right click on your connection and go to properties unclick the box where it say NOTIFY ME WHEN THIS CONNECTION HAS LIMITED OR NO CONNECTIVITY
  • 790 Answers
Hello!!
Do u have proper internet connection ???
And also try in other browsers too.. like mozilla or google chrome..
  • Kanth raj
    Kanth raj Nov 18, 2008
    1.Start - Run - regedit
    2.HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\explorer\BrowserHelper Objects
    3.If you get there, you will see few keys(look like folders) that are in numbers and alphabets.
    Delete all of them.
Need masster password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Nov 26, 2012 | Dell Inspiron 700M Notebook
Dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
Pictures wont load x in corner
Check to see if IE has had images turned off: 1. From Internet Explorer 7, click the "Tools" button.
2. Select "Internet Options".
3. When the "Internet Options" multi-tabbed dialog box appears, click the "Advanced" tab.
4. Scroll down to "Multimedia" and check or uncheck "Show pictures" as desired. Refer to the below screenshot.
Mar 10, 2011 | Dell Inspiron 700M Notebook
I have a Dell Inspiron 1525 that 2.5 years old. Lately after about 10 minutes or so, IE does not respond, hangs and goes to grey.
Those are the common issues with Internet Explorer. May I know the version of the Internet Explorer installed in the Computer? The best option is to reset the Internet Explorer and delete all the personal settings once. You can reset the Internet Explorer by following:
  • Open the Internet Explorer.
  • Click on Tools and select Properties.
  • In the Properties window, click on Advanced tab.
  • Now, click on reset and check Delete Personal settings option.
You can also change the Web browser to Firefox as it is more flexible compared to IE,
Jul 04, 2010 | Dell Inspiron 1525 Laptop Jet Black
Inter net wont let facebook thru erro inter net
There could be multiple solutions to this.
1) Update your flash drivers
2) Install the latest Inter net explorer
3) make sure your network does not have it blocked
4) If Internet explorer fails, try a different browser like Firefox.. etc..
Nov 18, 2009 | Dell Factory Refurbished E310-GDRK291...
I got a used Dell Inspiron 700m, no internet
HI,
if the port has light, this means the computer is detecting the internet signal . The problem could be some settings on the internet explorer.Maybe the previous owner might have made customer settings.
Reboot the system and when you see the Dell Logo screen . tap on the f8 key slowly 5-10 times
Select safe mode with networking from the list
Select the default os and hit enter
Wait till system takes you to a login screen
Login as the adminstartor
Click on Yes
Now try connecting to the internet
If the same works , create a new user account .
How to create a new account ?
1. click start >click control panel
2. Click on user account
3. Click on create new account
4. Restart the computer and login with the new account and try connecting
Thanks for using fixya
proton
Aug 28, 2009 | Computers & Internet
I want a driver for motherboard of dell inspiron 700m please
Hi, go to the internet and go to dell.com then go to drivers & downloads
then select your laptop model Inspiron 700m
OR
here is a link to get all your drivers for your model of dell Laptop Inspiron 700m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_700M&os=WW1&osl=en&catid=&impid=
hope this solved your problems
Nov 11, 2008 | Dell Inspiron 700M Notebook
Problem regarding internet explorer 6.0
k try this delete all temp files and cookies and restore the inter net explorer
to delete cookies and files follow this
open i-explorer ->in top->click tool->inter net options->general->delete temp files,cookies,clear history>
to restore the i-explorer follow this
open i-explorer ->in top->click tool->inter net options->click on advance ->in bottom click on restore default
and reboot the pc>if still the same issue then try with different browser
i hope this will help u rate me solved if this helps thx
Dec 02, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
