Question about Sony STR-DE598 Receiver
No custom names
Out of nowhere all my custom names got reset to default. When I go to change them back, "memory" flashes and it will not save my custom name, only the default names will work.
YOU HAVE TO SAVE THEM.IF THAT DONT WORK RESET THE RECIVER BY HOLDING THE POWER BUTTON FOR 5 SECONDS UNTIL IT SHUT OFF.
Posted on Jun 08, 2008
How to change default memoty settings in c101
No need to change the default memory....First of all delete all the internet browsing history.cache,saved pages..etc.Even if the problem persist just flash it by following this Click here1.or contact mobile repairing shop.For your flash file visit this page and download All nokia bb5 flash file.Good luck
Apr 04, 2012 | Nokia C101 Cell Phone
Hi I am able to click on camera, but after capturing and processing the image, its failing to save the image.I have enough memory in memory card. Please resolve the issues ASAP. reshma
The important is you need a free space on you phone memory.better delete some data to be able to use camera and other mobile features.
otherwise reset your phone. Go to settings > restore factory default and reset your phone. a code will be ask and then enter the default code which is 12345,if you change your code before,just enter your desire code.
note : if you reset your phone,be sure to back up all data before doing this resetting,cause everything will be deleted and it will go back to default.
good luck....
Jun 21, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
What is my wireless network username and password?
if its default it will be on the bottom on the sticker if it does not work look for a reset button it is usally red and only a pin size this will make the password on the bottom work
Feb 16, 2011 | D-Link AirPlus DI-524 Wireless Router
My hp 5200 printer prints extra sets of multi page documents when only 1 copy has been selected for output. Is this a printer setting that I can change? Is there someway to reset to its default settings?
Here ya go sir, this is a cold reset option and it will reset all back to factory defaults so if there are setting you want back, you may want to print out a config report prior to resetting...
1. Turn the printer off.
2. Turn the printer on. When the printer begins its memory count, press and hold down until all
three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
3. Release .
4. After SELECT LANGUAGE appears on the control-panel display, press or until COLD
RESET
is highlighted.
5. Press . The printer performs a cold reset and then continues its power-on sequence.
6. Check all I/O settings and reset any customer-set printer configuration values.
hope this helps and if so please mark this as a fixya for me sir...
Jul 02, 2010 | HP LaserJet 5200 Printer
I set the Ip address manually to 192.168.1.0 and now I can not connect to the media vault and/or the control center
That is not a valid IP address.
IP addresses must end with .1 to .254
I am surprised that it let you set it to zero
Best bet is to reset the media vault to factory defaults and then follow the manual to set it up. Go to support.hp.com for more info.
If this helps, please vote for my solution.
Oct 03, 2009 | HP 1TB HP Media Vault Pro mv5140
Lg xenon won't delete recent text messaging recepants
Unfortunately this is not an easy task...
I finally figured it out on my Xenon after weeks of playing with it and researching it...
1. Make sure all of your contacts in your address book are saved to your SIM card.
2. Make sure all of your photos, ringtones, etc are all saved to your Memory card.
3. Remove your memory card.
4 Go to Settings - then Phone - Then to Reset Settings.
5 Here you want to do a Master Clear. *Warning - this will take away all of your settings on your phone - and you will have to re-customize it. Choose PHONE and not memory card here. It will ask for a security code - by default, your code should be 0000.
6 Put your memory card back in and send out a "test" text to the top 5 people that you text... Those names will now appear in your Most Recent Text Recipients list.
It sucks, and it's a long process, but I can't figure out any other way.
Then you restore all of your settings manually (ringtones, picture wallpaper, etc.)
Hope that helps!!!
Jun 27, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Problem with D-Link wireless router!
try to reset your D-link router (press the reset button of at least 1min) reseting router will restore the manufacturer default router settings.
Note: Save or write any changes you made in your router if you customize it other than using the default settings.
Nov 24, 2008 | D-Link DIR-625 (790069292637) Wireless...
Gprs
you will need to ask your service provider to send you the GPRS/WAP settings for your handset.
they will text it to you, and then u save them and it will be listed in
Menu > Settings > Configuration > Default
select that setting and set it to be the default setting and then click on Act. Def. In all applications (this will activate default settings in all applications that use GPRS)
or if u knew the access point settings and all, u can add a manual setting and make that as default.
cheerz
Apr 28, 2008 | Nokia 7610
Caller id
try and master reset your phone back to the default.....
menu/settings/initial setup/master reset
Jan 10, 2008 | Motorola Mobility RAZR V3
Sony STR-DE598 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
