Question about Brother MFC 210C All-In-One InkJet Printer
Borhers does not print
Printer says yellow cartridge needed replacement however when I repleced it, it again said cartridge slot is empty and requests putting in a cartridge.
I replaced it with 3 new cartridges and still same problem.
Frank
  • terry103 Nov 18, 2008
    My printer ALWAYS says yellow cartridge is low
  • towtje Jan 29, 2009
    it is the black cartridge for me... and of course the whole thing doesn't work if one is "empty"... very frustrating... i thought "brother" is a good brand. ..... mm....
    New Friend:
Its says no cartridge then Open ink cartridge then reinstall ink cartridge
Posted on Jan 31, 2014
Printer says cyan cartridge needs replacement, however when I replaced it, it says that there is no cartridge.
Betty
Posted on Nov 29, 2008
Lexmarx X4975 disable complete-a-print
The Lexmark X4975 Professional is a multifunction thermal inkjet printer that not only prints documents and photos, but also makes two-sided printouts, scans and copies materials and accepts line-connected or wireless device print requests. Three color ink cartridges--cyan, magenta and yellow--and a single black cartridge rest inside an ink cartridge carrier. Printer cartridge replacement is not difficult. Each cartridge is secured in place with a cartridge carrier lid that opens with the simple press of a lever.
  • Turn on the Lexmark X4975 printer. Lift up the entire scanner unit to rest in an open, angled position that reveals the interior of the printer.
  • 2
    Press down on the lever in front of the printer cartridge that you need to replace to open the cartridge carrier lid.
    • 3 Pull the old cartridge from its slot in the carrier.
    • 4
      Grasp the tab attached to the tape covering the electrical contacts and ink nozzles on the back and bottom of the replacement printer cartridge. Pull the tape away from the cartridge carefully without touching the contacts or nozzles.
    • 5
      Insert the cartridge into the empty slot--the electrical contacts facing the back of the slot inserted before the front of the cartridge.
    • 6
      Flip the cartridge carrier lid over the top of the cartridge and then push down on the top of the lid until you feel the lever lock the lid in place.
    • 7
      Repeat the replacement process with the other printer cartridge if necessary. Lower the scanner back into position when finished.
      Increase Engine Horsepower.
Jun 02, 2012 | Lexmark X4975 3-in-1 Wireless Inkjet...
How do i install new cartridges into my tx printer first time user never changed before
With the printer on but not busy (flashing light), open the scanner unit. (Lift the scanner until the bracket on the right locks.)
If the cartridges are completely expended:
Press the Stop button on the printer, the print head should move to line the expended cartridge with the empty ink mark. Press Stop again and the next empty cartridge should line up with the mark. Continue to press Stop until the print head moves to the cartridge replacement location (after noting which cartridges need to be replaced).
One cartridge at a time, shake the new cartridge 5 times before opening the package.
Remove the new cartridge from the packaging and remove the yellow tape from the cartridge. Be careful not to damage the hooks on the side of the cartridge and do not touch the green IC chip. Leave the transparent seal in place.
Squeeze the tab at the back of the cartridge you want to replace and then lift the cartridge up. Then put the new cartridge straight into that slot and press down until it clicks.
Repeat this for all empty cartridges. Then close the scanner unit and press Stop. Wait until the light stops flashing and the empty ink error light goes out. The unit will charge the ink system while the light is flashing.
If the empty ink remains flashing or is on with the print head in the home position, then a cartridge may not be properly inserted. Press Stop and then push down on the cartridges. See http://support2.epson.net/manuals/english/spc/stylustx100tx101/guide/html/ink_4.htm for pictures and images.
If the ink isn't expended, use the Ink Replacement utility in the Epson software. For Windows, this is part of Printing Preferences in the Maintenance tab. Open the Devices and Printers (slightly different name in older versions of Windows) control panel. Then right click on the printer and choose Printing Preferences.
I hope this helps.
Dec 04, 2010 | Epson TX100 Series
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
1. Verify that the unit is on.
2. Open the ink cartridge door.
3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
1 - Ink cartridge latch for the black ink cartridge
2 - Ink cartridge latches for the color ink cartridges
NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
HP 3600N Printer 10.10.01 error
The printer cannot read or write to at least one
print cartridge memory tag, or at least one
memory tag is missing.
1. Open the front door.
2. Remove the print cartridges,
reinstall them.
3. Close the front door.
4. Turn the printer off and then on.
Mar 30, 2008 | HP LaserJet 3600n Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Brother MFC 210C All-In-One InkJet Printer Logo
263 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
