Question about Epson RX620 All-In-One InkJet Photo Printer
Epsom RX620 Poor quality photo prints
My RX620 printer recently aquired (nearly new) is producing darker than life and 'milky' photo prints.
I am comparing them to photos that are printed on my Epsom DX8450 which produces very good photos.
I would have expected the RX620 to be the superior printer. I have reset to factory settings, cleaned the head, and put new cartridges in. Can you suggest what else I should be doing?
Many thanks.
Richard
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Posted on Nov 19, 2008
New toner but printed output is too light and faint. What can I do?
Hi there !
You need to replace the drum unit of the cartridge and i believe that the part life had ended. you can view this on the LCD monitor of the printer. Go to menu and choose LAN setting. Choose machine parts and check the drum unit is it says life ended. You need to replace that drum unit.
Another way for temporary purposes, set your print quality setting to PHOTO setting. It will print darker than before but not on taking photocopy.
Feb 09, 2011 | Brother MFC-7820N Laser Printer
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
EPSON RX620 PRINTER WILL NOT INSTALL ON NEW WINDOWS 7 COMPUTER
This is where most Pc user fell prey to the new features of Windows 7. I agreed windows 7 is far more secure than any other Operating system that Microsoft has release till now.
But many forget to consider the point of hardware whihc they are going to use in day to day life really support Windows 7.
Only the scanner driver has been release by epson for your printer for windows 7. So there's no work out as they haven't even release drivers for windows vista too.
And you won't find the driver on net as nobody will write the driver program for any printer without the blue print of the printer hardware.
Soory again.
Jan 12, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Poor copy quality
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Jan 09, 2009 | Dell 1600n All-In-One Laser Printer
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
Print quality is very poor
I used to use an LX300 and have never had this problem. I'm not sure what unclear means so I will just do some guessing. Clarity of the print depends on 3 things, software, printhead and ribbon. These are your problem areas. Epson has an option to print NLQ or near letter quality. So that should give more clarify. I basically double prints the same letter to create a darker image. The printhead, if your printer is really old, you need to either find someone to refurbish the printhead or buy a new printhead because it could be the impact pins are bent and not giving the strongest image. Lastly the ribbon, obvsiously the more used the ribbon is the weaker the image. So either re-ink the ribbon or buy a new ribbon cartridge. Hope this helps.
Aug 05, 2008 | Epson Dot Matrix LX-300+ II Printer
Poor print image
You use your printer settings to set quality of image.
Jan 31, 2008 | HP Photosmart D7160 InkJet Printer
Epsom stylus photo printer 360
Make sure there is enough room for the CD tray to move through the back of the machine. Describe fully exactly whit is is you are trying to do.
Jun 17, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
262 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
