Question about Sony STR-DG510 Receiver
Sony STR-DG510 From component to HDMI
I have my tv connected with hdmi cable and my xbox360 with component cable to DG510 but i dont get picture.. Is it even possible to get it that way or do i have to place component cable between tv and DG510 also?
  • muinja Nov 18, 2008
    Nevermind. Already found the solution. Sorry
    Problem Solver:
  • 5 Answers
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Posted on Dec 22, 2008
My xbox restarts when i change to tv
Check these things:1. Is your XBOX360 using HDMI and COMPONENT CABLES?2. If you do have COMPONENT CABLE plugged in then my best bet is you're trying to play XBOX360 with 1080p which COMPONENT CABLES do not support.3. You may need to get an adapter(NOT RECOMMENDED) or just unplug COMPONENT CABLE (RECOMMENDED)lol.
Note:XBOX360 will restart itself when you switch between the two or even if you turn off and on, your TV.
My advice is to use one or the other :)
Hope this helps
TEEMAN
Nov 27, 2011 | Microsoft Xbox 360 Console
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Looking to connect HDMI cable from dellW5001c to xbox360
192.168.15.1
i am appling this password. then username and password appling . plz help me
what is password and username.
Dec 27, 2008 | Dell W5001C 50 in. Plasma HDTV
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
NO Picure
Hi 1prosource
I concur:) Glad you got it sorted out. Any other dramas you may have, just give me a hoy :)
regards
robotek
Jun 02, 2008 | Sony STR-DG510 Receiver
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
Sony STR-DG510 Receiver Logo
214 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
