Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Water very slowly fills Whirlpool washer
The water fills very slowly the Whirlpools supercapacity plus top loading washing machine.  Is there a filter some where in line?  The hoses are new
  • Anonymous Feb 01, 2009
    how do get to the water valve?l
  • Anonymous Mar 25, 2014
    Model Number WTW4950XW2 top load will not fill with water
  • 370 Answers
Check the screens inside the water valve. They get plugged sometimes. Also check both ends of your hoses. When installed most companies put screens or screen (1) in the cold water line at the valve.
Posted on Nov 19, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Whirlpool 'quiet wash plus' top load washer
the washer is over filling because the float part is bad see the link below for details Whirlpool Dishwasher Overflows Replace Float W10345285
Jan 07, 2018 | Washing Machines
Washer fills slowly
Check for MINERALS in the fill valve screens where the hoses connect.Most likely the hot side is the one that is plugged due to hot water tank sediment. Clean screen and replace hose with NEW RUBBER WASHERS!!!!
Jul 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine fills with water ok but won't agitate completely, will empty the water but will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
172 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
