Question about Microsoft Windows XP Home Edition
Category view in control panel windows xp is missing
Do not know how this happen. Turned computer on and went to control panel and it was in the classic view. The side panel showing where it can be switched to Cateory View is gone. How can i get the Category View back?
This is how i solved this problem
Go to
Start/Run/Regedit and navigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer and then just delete the file called ForceClassicControlPanel and then exit the registry and
the switch to category view should show up.
i hope this helped you
Posted on Dec 28, 2008
    Problem Solver:
  • 18 Answers
Howdy, Ursha60, and welcome to Fixya.com.
That is kind of a common thing, especially when you have someone who prefers the older style. That side bar is called Common Tasks by windows options. Simply click Tools on the bar above and then click "Folder Options" On the "General" tab you should see "Show Common Task in Folder." and "Use Windows classic folders." Simply check (or dot as the case may be) "Show Common Task in Folder" then click apply.
Hope that works out for you, if not let me know. If you have anymore Windows XP problems go ahead and post them and I'll be sure to give you a response quickly.
Posted on Nov 19, 2008
I need help to create a new account in microsoft outlook for e-mail?
For Windows 7:
  • If Control Panel is in either Large icons or Small icons view, click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category view, under View by, click to select either Large icons or Small icons, and then click Mail. The Mail Setup dialog box appears.
  • Click E-mail accounts
  • Select the E-mail tab, click New...
For Windows Vista or Windows XP:
  • If Control Panel is in Classic View, double-click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category View, under Control Panel, click Switch to Classic View for Windows XP, or click Classic View for Windows Vista, and then double-click Mail. The Mail Setup dialog box appears.
Alternatively, in Outlook, select the File group at the top.
Click INFO, then add account.
Jun 23, 2011 | Microsoft Office 2010
Change language
There are many ways to change the language of your pc. Below is one of the method.
1. Click on the menu button on the taskbar.
2. Click on the control panel icon
3. Now I need to know the way you use your Control Panel
4. If your control panel has a blue background. You are using Category view
5. If it has a white background ( This is the same as opening a folder on your computer ) then you are having classic view
Now. The change of language depends on your view ( Either classic or Category ( Explained above ))
Classic view
Classic view will make it much easier for you to change the language.
1. Once control panel is opened. You should find a folder named "Regional and language options"
2. Double click on this icon.
3. A window will pop-up
4. Then there you can change the language. ( to change it is the first thing on that window )
5. Default is English (UNITED STATES)
Category view
1. Fire up your control panel
2. Click on te icon " Date, time, language and Regional Options "
3. Then down under the category "or pick a control panel icon "
4. click on "Regional and language options "
5. A window will pop- up
6. Change the language ( To change the language it is the first things that appears on that screen
7. Default is english (UNITED STATES)
Your feedback is greatly appreacited. Thank you for using FIXYA.
Jun 17, 2011 | Sony VAIO Notebook
Change language on laotop
There are many ways to change the languange on you pc below is one of the method.
Classic view
Category view
Your feedback is greatly appreciated. Thank you for sung Fixya
Jun 17, 2011 | Sony Computers & Internet
How do I reset the monitor to correct font size
Hello Lawrie,
You don't actually adjust fonts or resolution on the monitor, you do adjust them in the control panel of the computer. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or adjust resolution from the left column(Vista/7), now find the slider bar for resolution and slide it higher if you want the font smaller or lower if you want the fonts larger. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply button simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps Fixya,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Jan 01, 2011 | LG Flatron L1750S 17" LCD Monitor
How to change computer language
Classic view
Category view
2. Click on the icon " Date, time, language and Regional Options "
5. Change the language ( To change the language it is the first things that appears on that screen
6. Default is english (UNITED STATES)
NOTE:- To change back ( since it will be in a different language, remember the placing of the icons.
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Lost wireless connection and yet it works with other computers... do I have an on/off switch on a Gateway 600y?
To turn the wireless emitter on or off in Windows XP:
1 Click Start, then click Control Panel. The Control Panel window opens. If your
Control Panel is in Category View, click Network and Internet Connections.
The Network and Internet Connections window opens.
2 Click/Double-click Network Connections. The Network Connections window
opens.
3 Right-click Wireless Network Connection, then click Enable to turn on the
wireless emitter or click Disable to turn off the wireless emitter.
Aug 17, 2009 | Gateway Computers & Internet
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
How to roll back an accidentaly downloaded windows media palyer SPANISH version
Rolling back to a previous version of the PlayerWindows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, in Windows XP, you can roll back to the version of the Player that was previously on your computer.
You must be logged on as an administrator or a member of the Administrators group to perform the following procedure.
  1. Disconnect any portable music or video devices that might be attached to your computer.
  2. Click Start, and then click Control Panel.
  3. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  4. Click Windows Media Player 11, and then click Remove.If Windows Media Player 11 is not displayed in the list of currently installed programs, then try the following:
    1. At the top of the list, select the Show updates check box.
    2. In the Windows XP - Software Updates section, click Windows Media Player 11, and then click Change/Remove.
  5. In each of the two confirmation dialog boxes that appear, click OK.
  6. When the rollback process is complete (it might take several minutes), click Restart.
  7. Click Start, and then click Control Panel.
  8. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  9. Click Windows Media Format 11 Runtime, and then click Remove.If Windows Media Format 11 Runtime is not displayed in the list of currently installed programs, then try the following:
    2. In the Windows XP - Software Updates section, click Windows Media Format 11 Runtime, and then click Change/Remove.If you installed a non-US English version of Windows Media Player 11, the instructions in the dialog boxes that are mentioned in steps 9, 10, and 11 might appear in English.
  10. In the first confirmation dialog box that appears, click OK.
  11. In the second confirmation dialog box that appears, select the Do you want to continue with the rollback? check box, and then click OK.
  12. When the rollback process is complete (it might take several minutes to complete), click Restart.
  13. Click Start, and then click Control Panel.
  14. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  15. Click Microsoft User-Mode Driver Framework Feature Pack 1.0.0, and then click Remove.
  16. Follow the instructions that appear in the Software Update Removal Wizard. If the Wudf01000 confirmation dialog box appears, click Yes to continue. When the software removal process is complete (it might take several minutes to complete), click Finish.
May 02, 2009 | Computers & Internet
Firewall setting dowload cant download
Usually the firewall settings are found in Control Panel on your computer. If you are running Windows XP, click on the Start button and select "Control Panel" from the right side of the menu. Select "Windows Firewall" (or if you are in Category view, "Security Center" then "Windows Firewall"). Under the "Exceptions" tab, if Yahoo! Messenger is not already in the list, click "Add Program", then select from the list shown. If Y! isn't shown, click "Browse", then select Y! (usually can be found under C:\Program Files\Yahoo!).
Apr 27, 2009 | Yahoo Messenger
I have IBM R40 Laptop
Try pressing the power button next time. That will help you to turn on from an Hibernation.
Alternative you can disable this feature (not recommended for laptops)
  1. Open Control Panel.
    • On the Windows XP default Start menu, click Control Panel.
    • On the Windows XP classic Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, open Power Options.
    • If the computer is in Category View, click Performance and Maintenance, and then click Power Options.
    • If the computer is in Classic View, double-click the Power Options icon.
  3. In the Power Options Properties dialog box, click the Hibernate tab.
  4. On the Hibernate tab, clear the Enable hibernatation check box, click Apply, and then click OK.
Jan 10, 2009 | IBM ThinkPad R40 2897 Notebook
Microsoft Windows XP Home Edition Logo
389 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
