Question about Freezers
Wont start up
Moved chest freezer from one houe to another and it wont come back on
  • sdelfra Nov 19, 2008
    Please help. Mike. I need this for Thanksgiving.
    Novelist:
  • 124 Answers
Pretty basic stuff. power cord could be abaded . check to be sure power is reaching the stat with a meter. if it is then check to see if its reaching compressor with a meter, obviously the box is hot so sta t should be calling if power arrives at stat but doesn't come out stat is bad. if it gets to compressor but no run then the compressor start components or the compressor itself are bad. stat has a power in lead and a power out lead. if you check volts between terminals and show 120 the stat is open and bad. if it is set to max cold and failing to send run signalit has to be the stat. if you have power to stat and stat shows no voltage terminal to terminal then its closed and power is not getting to compressor, trace wiring and check .if power is getting to compressor the checjk start cap and relay . if they are good then compressor is bad , usually to expensive to replace.
Posted on Nov 21, 2008
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
I moved my freezer on its side to clean and it wont get cold any more what do i do/
Fridges and freezers often don't like being started right after they have been moved/tipped, it's best to give them some time (a few hours) in the upright position to allow the refrigerant fluids to settle back where they're supposed to be before restarting.
Jun 29, 2011 | Danby 5.5 cu. ft. / 156 liter Chest...
Briefly unplugged and now when plugged back in freezer wont turn on?
fairly unusal but ...posibly vapour locked.... people transporting fridges and freezers laying them down or chest freezers standing them up in a truck or trailer (taking them to the cottage) have this problem all the time unplug it for 24 hrs should cure it Good Luck
Oct 12, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Moving, CA to Florida and want ot load a chest freezer on its end
You could expect internal compressor oil to flow into areas which would restrict refrigerant flow, resulting in no cooling. If you have to ship on end, make sure the compressor end is down !
Jun 07, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Moving a freezer
By front, I presume you DO NOT mean the top. In that case, either should be fine.
Dec 09, 2007 | Freezers
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
127 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
