Maytag bearing issue
Do I need just the main bearing or do i need the bearing kit also. Maytag Legacy Series 13 #sav205daww
  • 370 Answers
Get the kit.
Posted on Nov 18, 2008
  • Justin Duby
    Justin Duby Nov 18, 2008
    I did some research, Just changing the main top bearing should fix it up.
What is the position of the belt on a Maytag Legacy SAV205DAWW? On the right or left of the idler pulley?
Sounds like the pump pulley is not in the rotation. Since there's only 2 options if its not working on the way you have it now, it must be the other.
Aug 31, 2014 | Maytag Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Remove the front of the washer to get at the water pump sav205daww
I have never messed with one of these with 2 front panels but it looks to me like you remove the 2 screws at bottom like the old series and get the toe kick off first. Then remove or back off some screws at the base of the front panel and then compress the top springs to release the panel. Here are some old school pix
Sep 11, 2009 | Maytag Legacy Series Top Load Washer
ROARING SOUND IN SPINN CYCLE
your bearings are shot your washer needs to be rebuilt it would be cheaper to go buy a new machine
Dec 23, 2008 | Maytag Legacy Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
MAYTAG WASHER SAV205DAWW
This calls for some dis-assembly of the washer. Are you still looking for assistance ?
Jan 01, 2008 | Maytag Legacy Series Top Load Washer
Maytag legacy load spin cycle
It is your main bearing, I don't recommend doing it yourself. You will need a special spanner wrench that you'll use only once. To see an exploded view go to Sears Parts
Aug 07, 2007 | Maytag Legacy Top Load Washer
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
