Question about Palm Treo 700p Smartphone
Error 0.14 I have an Palm Treo 700p device and not boot, the screen show 8 color square. Red - White Green - Red Blue - Green White - Blue
  • 3 more comments
  • snpchrisa08 Jan 29, 2009
    i am having difficulty with this as well, and i have been taking the battery in for hours and still no luck.
  • Anonymous Jan 31, 2009
    I just starting having this problem today. I tried taking the battery out and I tried hitting the reset, but I still have the color blocks.
  • jamieedwards Feb 14, 2009
    Colored squares.. nothing works to get rid of them.
  • Anonymous Mar 19, 2009
    My phone had been trying to sync itself all day and I had never even synced it before. Then it started doing this WTF?
  • Anonymous Apr 02, 2009
    This has happened with my old Treo 650. When I hot synced, it fixed it. Now it is happening with my 700P and it wont work.
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Posted on Jul 29, 2009
    Sergeant:
    Champion:
  • 258 Answers
Take the battery out, wait 5 seconds, replace it. If this doesn't help, then send it in. What you are seeing is the bootloader screen. It might come up if the cable is plugged in during reset. though the sync button is supposed to be involved. It's possible there is a short in the sync connector.
Posted on Dec 07, 2008
When you turn on Treo you get an error message 'update ROM Image?' If you select yes is displays ROM Image not found and then displays a screen with 8 multi-colored squares
"rom Image" is reffering to the operating system on the phone, this is common when rooting android phone but not sure on treo, check treo website for "rom update" may have to plug ur phone into your computer to doit. hope this helps
Oct 26, 2010 | Palm Treo 755p Smartphone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Treo 700 P red, white, blue, green checkered screen
Jul 28, 2009 | Palm Treo 700p Smartphone
Hot sinc stuck in a loop, then red white blue and geen screen
Reset the 700p then resync it with the latest Desktop Manager:
http://kb.palm.com/wps/portal/kb/common/article/42094_en.html#treo700p
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 23, 2009 | Palm Treo 700p Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Blue green red white squares on frozen screen
The exact same thing just happened to me too! Tried soft and hard reset. Nothing.
Jun 03, 2009 | Palm Treo 700p Smartphone
Phone frozen: The screen just shows boxes of red, green, blue and white.
Just had the same problem. When you take the battery out, leave it out for 4-5 minutes. Then when you put it in and reset while holding the on/off red button, it should start. Mind did. Good luck.
Stacy
Sep 07, 2008 | Palm Treo 700p Smartphone
Palm 700P stylus problems
it sounds like it could be a warrenty issue, if you have restoreed the device and its still not working then you would need to get it repaired or replaced
Jun 11, 2008 | Palm Treo 700p Smartphone
Resurrection
Sadly the chances are not high. the bootload screen tells you that Palm OS has not even loaded, assuming you have tried a soft reset this would suggest that the devices memory is either inaccessible or damaged. Anything you try is going to be a slim chance but what do you have to lose by trying? If you reset your palm with it plugged in to your PC via a USB cable there's a small chance you may force it to act as a USB memory reader, as such it will show up in My Computer as a drive or if you have a memory card in the phone it will show up as 2 drives. I cannot stress enough that this is a slim chance though. If you are familiar with telnet and serial data communications it is stall possible to access a palm this way and possibly find your data, however this is a very involved procedure that will require a steep learning curve if you don't know what I'm talking about and still represents a very slim chance.
Aug 11, 2007 | Palm Treo 650 Handheld
Palm Treo 700p Smartphone Logo
476 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
