Question about Nvidia GEFORCE 4 MX440se / MX 4000 VIDEO CARD GEFORCE4 64MB TV OUT Graphic Card
Out of scn range
Monitor is working out of scan range change pc setting
  • 3 more comments
  • lindal3 Nov 18, 2008
    monitor is a dell a old one
    800X600 I change this to what you said but I used to play build-a-lot game and now I can not I just do not know why I can play allother games still like before just not this game I own this game.
    P780 DP/N075UXR/C/O MX/ REVA00 DSN MX - 075UXR - 47741-172-80PS NOM166
    Thank You but they need money and I do not have any right now!
    Sorry it still does not work I just can not play that game.
    Sergeant:
  • 207 Answers
Linda,
This simply means that the resolution you have set is beyond the display capabilities of the monitor.
If you can see a visible picture on the monitor, it is likely that you either have the "Generic vga/svga monitor" driver installed or an improper driver.
This can be easily resolved by simply going to the website for your monitor's manufacturer and downloading the right driver for your model of monitor and install it.
If you can't find the website for your Monitor's manufacturer, please post BRand and model info here and I will try to direct you there.
If you DON'T have a viewable display this is how to solve it.
When booting up the pc you'll see POST information flash on the screen or a company logo once this flashes off then push and hold <F8> and you should get a startup screen with several options
The one we want is "Start in Safe mode" select that
Once you have booted up into safe mode, open the display properties screen and change your resolution to something a bit lower (Almost all modern monitors can display 800X600 at a refresh of 75Mhz) so this may be a good place to start. Apply your changes and reboot.
Now you should be able to adjust your display settings to either the maximum displayable setting for your monitor. If you should change the setting and the monitor becomes unviewable (be careful not to push any keys and wait) the screen should change back after 12 seconds unless you confirm the change.
Hope this helps you,
Dave
Posted on Nov 18, 2008
Monitor is bright somtimes and sometimes dim
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 27, 2011 | Dell Inspiron 1521 Notebook
The picture on laptop monitor is sideways
also
hope this helps
don
Feb 27, 2011 | Gateway M-6834 Notebook
Monitor will rotate but the screen won't switch from horizontal to verticle position
control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
hope this helps
Dec 11, 2010 | Computers & Internet
I cant seem to change the color of the video, yet I did it earlier. WHERE IS THE SETTING FOR CHANGING COLOR!!!
There is no colour setting for the video.
You might have set the SCN/ISO before switching to the video.
You can adjust the ISO within Camera settings.
You can change the SCN within the SCN option.
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
Displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
Jun 02, 2009 | Yamaha Music
DELL P780
1. change the system frequency 60 Hz
2. settins change 1024 by 768 pixels
Nov 18, 2008 | Dell 17" Monitor
Out of scn range
Hi
Click StartGo SettingsControl Panel  Display Settings your screen 1024*768 select  it and 32 bit color quality also.. apply it ok..
it will work.
Nov 18, 2008 | Dell P780 17" CRT Monitor
Out of range
Setting the Refresh Rate in Enable VGA Mode - Windows XP
You will need to go into Enable VGA Mode to change the refresh rate.
  1. Restart the computer and repeatedly tap the F8 key on your keyboard until the Windows Advanced Options Menu appears.
  2. Select “Enable VGA Mode” and press Enter.
  3. If asked to choose your operating system just press Enter.
  4. Once the computer has finished booting up go to Start -> Settings -> Control Panel -> Display -> Settings -> Advanced -> Monitor.
  5. Change your Refresh Rate/Refresh Frequency to a lower setting.
  6. Click Apply to confirm the change.
  7. Close all open windows and restart your computer.
* Click here for help determining the optimal refresh rate for your monitor
Sep 24, 2008 | Computers & Internet
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Computers & Internet Logo
147 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
