Question about ASUS P5PE-VM Motherboard
F1 and sound problems on this mother board
At the time of starting, F1 error occurs, and after using this mother board for 3-4 mounth, sound are not found...we, three friends purchased this P5PE-VM mother board and we all forced to reject them after 11-12 mounth.....
    President:
  • 1,073 Answers
I have that MB myself, and i have non problems what so ever.
To pass that F1 problems u can sett in bios "Stop at no error",
To get the sound try to reinstal the drivers, not from the folowing CD, download them from ASUS site
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Nov 20, 2008
How do I re-boot and old linovo R61i laptop
take the new battery out
see if it will kick start just on mains power
if you hear a beep as it powers up mother board is ok
if the mother board is dead and no beeps it wont start up
try this each time from power up
if you hear a beep hold down
one of these F5 of F1 or F 12 wait to
see if a menu from the mother board itself is visabe
then follow the prompts
if nothing also suspect hard drive or chip failure
Jun 19, 2016 | Lenovo ThinkPad R61i Laptop
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
Error code: 2000-0333
hello
error code 2000-0333.
Possible cause Graphic Card Test Failed, Mother Failed, if your Notebook is under Warranty it is better to bring it to Service Warranty Center. or you can repair it by checking the mother board or video card. This problem occurred when your graphic or mother board is failed to start or initiate during start up.
thanks
pls rate
Apr 07, 2011 | Dell Inspiron 1545 Notebook
Frequent beeping sound with a display of F1 on the digital clock screen. This problem occur at all times night and day.
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
There is a beeping sound and F1 shows up in the display
These errors generally mean the control board has failed in one or more ways. F1 is by far the most prevalent. When this happens you need to replace the control board. You may be able to buy a new board or have us (www.fixyourboard.com) repair it (particularly useful if the board has been discontinued by the manufacturer). We have many DIYers who remove their control board and send it in for repair.
On some models it is possible that F1 could also be caused by a keypad problem. In this case it will specify in the tech sheet to power down the oven, disconnect the keypad then power the oven back on, wait for a few minutes to see if the error reappears. If the error reappears it is definitely the control board. If not, it is probably the keypad but be aware that F1 usually starts out as being an intermittent fault, then gets more prevalent with time.
In the Jennair case you need to send the clock, relay board (2 for double oven) and connecting cable that hooks them together. All 3 (4) have potential F1 failure sources.
Aug 05, 2010 | Jenn-Air Electric Double Oven
When i start my computer it gives an error "CMOS cheksum error, press f1 to continue.defaults loaded"
This normally means the CMOS backup battery on the motherboard needs to be replaced. Most boards use a commonly-available 3-volt coin cell. It just pops into a holder on the board. Change the battery and that message should quit bugging you.
Jun 13, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
F1 appears after you press the start button
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5PE-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
