Question about Dell P780 17" CRT Monitor
Out of scn range
Monitor is workig out of scan range change pc setting
  • lindal3 Nov 18, 2008
    no it did not work
  • 36 Answers
Hi
Click StartGo SettingsControl Panel  Display Settings your screen 1024*768 select  it and 32 bit color quality also.. apply it ok..
it will work.
Posted on Nov 18, 2008
Monitor is bright somtimes and sometimes dim
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 27, 2011 | Dell Inspiron 1521 Notebook
The picture on laptop monitor is sideways
also
hope this helps
don
Feb 27, 2011 | Gateway M-6834 Notebook
Monitor will rotate but the screen won't switch from horizontal to verticle position
control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
hope this helps
Dec 11, 2010 | Computers & Internet
I cant seem to change the color of the video, yet I did it earlier. WHERE IS THE SETTING FOR CHANGING COLOR!!!
There is no colour setting for the video.
You might have set the SCN/ISO before switching to the video.
You can adjust the ISO within Camera settings.
You can change the SCN within the SCN option.
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
When i power on my benq fp731 monotor it comes on then go's blank
monitor cannected to server its workig but after some time going dispayed out of rang
Dec 23, 2009 | Computers & Internet
DELL P780
1. change the system frequency 60 Hz
2. settins change 1024 by 768 pixels
Nov 18, 2008 | Dell 17" Monitor
Out of scn range
Linda,
This simply means that the resolution you have set is beyond the display capabilities of the monitor.
If you can see a visible picture on the monitor, it is likely that you either have the "Generic vga/svga monitor" driver installed or an improper driver.
This can be easily resolved by simply going to the website for your monitor's manufacturer and downloading the right driver for your model of monitor and install it.
If you can't find the website for your Monitor's manufacturer, please post BRand and model info here and I will try to direct you there.
If you DON'T have a viewable display this is how to solve it.
When booting up the pc you'll see POST information flash on the screen or a company logo once this flashes off then push and hold <F8> and you should get a startup screen with several options
The one we want is "Start in Safe mode" select that
Once you have booted up into safe mode, open the display properties screen and change your resolution to something a bit lower (Almost all modern monitors can display 800X600 at a refresh of 75Mhz) so this may be a good place to start. Apply your changes and reboot.
Now you should be able to adjust your display settings to either the maximum displayable setting for your monitor. If you should change the setting and the monitor becomes unviewable (be careful not to push any keys and wait) the screen should change back after 12 seconds unless you confirm the change.
Hope this helps you,
Dave
Nov 18, 2008 | Nvidia GEFORCE 4 MX440se / MX 4000 VIDEO...
My camaras flash is not workig
Hey kearlainye,
I would first make sure the flash is not set to off which is symbolized by a lightning bolt crossed out. If the camera is set to one of the scn modes the flash does not fire in night landscape and manner/museum modes. If neither of these options help I would have the camera looked at by an authorized service technician. You can bring the camera to a Geek Squad® precinct in a Best Buy™ store and they can look at the camera and if need be send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Kodak EasyShare C613 Digital Camera
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Dell P780 17" CRT Monitor Logo
170 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
