Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture or Color Problems
Hi
The problem I have with this tv is an intermitent change in the picture from normal to something to negative (dark) with colors, some times I see a white horizontal lines or bars and the picture is ok again for a few seconds and again the picture is dark. I try to play a dvd by the RCA connectors and the result is the same.
Thank You and Regards
Fernando
    Genius:
  • Sony Master
  • 1,689 Answers
There may be an intermittant fault on the CRT driver board, or there is an intermittant breakdown in the CRT electron-gun area. CRT problems are more common in these TV sets.
Jerry G.
Posted on Nov 25, 2008
I have a Samsung 46 " LCD that is 2.5 years old. We had 3 capacitors replaced about 2 months ago, tv clicked but wouldn't come on.Now we have a new problem. The picture will be dark for awhile and then it...
No,this problems it the T-CON decoders board problems.This board sit right in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 16, 2010 | Televison & Video
My almost 10 yr old Mitsubishi HDTV intermitently has color flux
The Main issues with the Mitsubishi HDTVs that size are the projection bulbs in the rear. A large TV like the Mitsubishi can allow dust build up on the lamps and the mirror in the rear that projects the picture to the screen. An easy fix would be to clean off the dust off of the mirror and bulbs. You would need to go through a tough processto do this since the mirror can be quite heavy and is in an ackward place. The only other alternative would be the need to replace the projection lamps themselves which can cost any where fromm $150 - in some cases $300 a piece for the lamp itself. The Television is still a great set but can cost quite a bit right now to fix if the problem is with the Lamps. If you can afford the Lamp replacement if it is needed the set would last you another 10 years plus. If you wouldn't like to go through the hassle of repairing the set or finding a place to repair the set there are so many new sets out in the market that will give you an amazing picture and quality.
Mar 29, 2010 | Mitsubishi VS-45607 45" Rear Projection...
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Picture problems after satellite installation
i had that same problem with my at&t dvr box the tech they sent out said the tv and box when hooked up with an hdmi cable were not compatible said they were working on the problem. what he did was give me home good hi-def cables to hook up tv works fine now
Jun 28, 2009 | Hitachi 51F59 51" HDTV Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Picture darker/less color/smaller until warm up
Hi there!
Have you checked for dust on the Tubes and mirror? This may cause a bad picture quality. Also power supply related problems like capacitors can cause a dark picture. Try replacing some of them in the power supply area and line stage.Also adjustments in the service mode,but for this you will need the service manual. Good Luck,JUS004
Oct 15, 2007 | Mitsubishi VS-55707 TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
