Question about IBM E74 17" CRT Monitor
Monitor menu keeps on coming again and again.
Please help me since 2 3 days my monitor menu i.e through which we adjust the contrast,brightness,etc that menu is coming and goin again and again even when i press exit button it keeps on coming.I have an IBM E74 Monitor.
  • 4 more comments
  • Anonymous Jun 10, 2008
    Do you have an alternative solution to this problem? The problem of sudden appearance of IBM E74 Monitor menu, (with which we adjust the contrast, brightness, etc) has become more frequent these days than it was a couple of months back when I used to rather ignore it. Pressing exit button does not help. However, switching off the monitor at that point and switching on again gives temporary relief. I am baffled about the possible reason for occurance of this kind of problem. Could you please explain the reason and the remedy. Thanks & Regards,
  • justmilan Jun 23, 2008
    I have similar issues with IBM E74 - i am just fed up of this issue - pls help me to understand why it happens and how to resolve it
  • rama_70 Jul 28, 2008
    same problem faceing
  • venkiii Jul 28, 2008
    same problem we r facing
  • Anonymous Jul 31, 2008
    on screen display is flashing
  • Anonymous Aug 08, 2008
    The contrast comes on and on again. When the monitor menu is activated, it goes on at a speed without pressing any button. The contrast menu keeps popping and disturbs
Is there is any others solutions?
Posted on Oct 05, 2008
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
How to adjust the 'hue' on a logik log19wh7
Try performing reset from the menu option.
if problem persists then get back to me
Regards
-Dileep Bradley
Mar 18, 2009 | Star Logic 17" LCD Monitor
Monitor display
Appreciate the direct "Ask Me"
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Computers & Internet
Display on menu
Hi again,
It would seem that you posted your problem several times. As stated in my proposed solution in your other postings:
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Dell 991 monitor
On the front of the monitor is a menu button. Press it, and using the left and right buttons on the monitor navigate through the menus until you see brightness, contrast, etc. Then adjust them as necessary.
Steven
Sep 17, 2008 | Dell M991 19" CRT Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
IBM E74 17" CRT Monitor Logo
361 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
