I have a ECS GF8200A black series motherboard.. and it blue screen when I add 4gb of ram.. 1gb sticks = total of 4gb.. pc26400. It works fine with 2 sticks even 3 sticks once I add the 4th.. it blue screens. I have ran memory test with 2 sticks, then with 3 sticks.. all works fine.. then the 4th stick, it blue screen what can I do.
  • ebusnies Dec 03, 2008
    I have the same trouble with GF8200A BS, (4x1 OCZ PC6400 platinum r 2.0) i thinked it was OS fault, and so installed a Vista 64 (SP1) OS, and never worked fine (except when 1 or 2GB RAM was used).
    I tried with Ubuntu 8.04 (64-bit) and the failure persisted.
    Tried with ganged and unganed modes but nothing.
    Tried updtaing BIOS but just keep pissed off....
    The solution? Use only 2 GB or throw away the card =P
  • Anonymous Dec 19, 2008
    I am having similar problems.
    Vista 64 SP 1, Blue Screen with 2 x 2gb DDR2 6400 corsair.
    After reading this, I tried:
    Ubuntu 8.04 64 bit, no problems with 4gb of mem.
    Vista 64 SP 1, 2gb no problems
    Seems like maybe Vista problem for me. Installing all the latest updates and will try 4 gb again. Will post results.
  • 244 Answers
SOURCE: Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Posted on Nov 24, 2007
Pterocarpous
  • 202 Answers
SOURCE: 4gb ram in foxconn n15235
Hello Jobedy
Everything I found pointed to this board being installed in a Packard Bell computer. One listing indicated the board supported up to 2GB of RAM. So, apparently, 4GB won't run on this system.
Your RAM DIMMs are fine. They're reading 1GB ea when inserted because that is the maximum supported per DIMM slot.
So, in the end, the issue is the limitation w/ your motherboard.
SOME HELPFUL INFORMATION:
When you're trying to find info or support on parts installed in an OEM computer (like a Packard Bell), you'll usually have much better luck searching or requesting support using the computer model no. in addition to the (for example) motherboard model no.
The reason is, (w/ respect to motherboards), most are special made by the original manufactuer for the computer manufacturer. They aren't usually going to be "off-the-shelf" motherboards for which documentation and support will be made readily available to the public.
Having the model no. of both the major assembly (computer) **and** the subassembly (motherboard) is the best combination to strike. :)
If you have more questions on this topic, please, let us know. We're happy to help.
If I answered your question, please, take a moment to provide a "FixYa" rating to my solution.
Thank you for using FixYa!
BJ @:)
Posted on Apr 16, 2008
sparky1500
  • 1066 Answers
SOURCE: ibm netvista 6794 ram upgrade problems
CL- pc13 memory is reccomended. 512k memory sticks of the pc133 variety give a lot of users problems, you have to find a specific type of memory when installing 512k chips. to get all 3 to work, i sugfgest using 3 sticks of the exact same type (same memory modules on each stick)
Posted on Dec 29, 2008
  • 597 Answers
SOURCE: ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Posted on Oct 04, 2009
SOURCE: A7s333 motherboard 3 dimm ram slots 2 x 1GB pc2700
well u need to check if the both rams are compatible or not with same Mhz speed.....
Posted on Oct 24, 2009
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Dec 02, 2012 | EliteGroup ECS P4VMM2 Supports Intel...
What ram do I upgrade with,,cant seem to find the right pin number etc,..there are 4 slots..can i use them all
The specs for the RAM on this motherboard are:
DDR400/333/266 SD RAM with ECC. Maximum you can use is 4Gb in total (so 1Gb stick in each slot would be fine - just make sure you match them in pairs).
Maximum of 4GMaximum of 4GB of DDR400/333/266 SDRAM with ECCB of DDR400/333/266 SDRAM with ECC
Jul 26, 2011 | Chaintech 9CJS ZENITH Motherboard
I have a G41T-AD motherboard i installed 4GB of RAM in it on wednesday and since then it keeps blue screening saying to check my hardware is there anything that i can do for this issue
Test the Ram dimms, one at a time. It sounds like you may have a bad module. Carefully reseat each one. And ground yourself to avoid static electricity.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 16, 2011 | EliteGroup ECS G41TM6 Core 2 Quad Intel...
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
Hey, I have an ECS GF8200a with ddr2 1066mhz 2gx2 ram from team Xtreem. Ram will only run at 800mhz, ? everything seems up to date like drivers etc.
The speed of system RAM is dependent upon the RAM itself for the most part. Check the label on the RAM sticks as this will indicate the speed of the sticks. Also, the system will only ever run system RAM at the speed of the slowest stick. So if you have two sticks, one rated at 800Mhz and one at 666Mhz, then the system RAM speed will be at the lower 666Mhz speed for both sticks. I would guess that the sticks you have installed will not run at the highest bus speed of 1066Mhz. The RAM controller may also be detecting that running the RAM at the higher speed may or will cause system instability and is reducing the speed to maintain a stable system.
May 21, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
4 Gigs or Ram?
Have you taken a look at page 2-12 in you're manual? Than re-check pg. 2-11 (Read everything) when setting up the Max memory of 4GB.
Mike
May 04, 2008 | ASUS A8N-SLI Deluxe Motherboard
Windows xp
hi
is this your motherboard? http://shop.pcmag.com/shop/product_specs/Intel+D915GAG+BLKD915GAGL10+Motherboard/22673983.aspx
if so, it is ok for you to upgrade your memory up to 2gb. btw, just be sure to properly install the rams to the slots.
since youve purchased 2 x 1Gb ddr400 , put on color blue slots.
hope this helps
Jan 23, 2008 | Intel D915GAG Motherboard
Nov 23, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
371 people viewed this question
Alun Cox
David Payne
David Payne
