Question about Frigidaire FSC23F7D Side by Side Refrigerator
Condenser icing up
The condenser coils located in the freezer section keep icing up about every 4 days. I have the freezer temp control on lowest setting, but my ice cream remains rock hard. When the coils ice up, the cold air flow to my refrig stops. I have defrosted the freezer and the coils and all works well for about 3-4 days before the problem returns. I have a side-by-side model FRS26ZshB1. Thanks.
    Problem Solver:
  • 8 Answers
I would suggest the evaporator heater or thermal fuse (if applicable) has failed.
Posted on Aug 20, 2017
fridgetech
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Posted on Mar 30, 2008
  • 51 Answers
SOURCE: dorm refrigator icing up
Make sure the fridge and freezer are not packed with food. It needs a lot of breething room.Also make sure the door is seeling tight. Not a lot of room in small fridge. Good luck
Posted on Sep 08, 2008
  • 56 Answers
SOURCE: Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Posted on Mar 30, 2009
SolutionGuy
  • 331 Answers
SOURCE: refrig. section not getting down to proper temp.
Hi Ron,
That was excellent description of the problem! Nice diagnosis, too!
The Adaptive Defrost Control board is located in the control section. It's part # is 4388932. I made this little diagram for you to assist you in gaining access to it.
Let me know, if you have any trouble, OK? Otherwise, don't forget to rate this solution and thanks for using FixYa!
SG
Posted on Apr 03, 2009
We first noticed the freezer in our 4 yr old Frigidaire Refrigerator with top freezer (Model FRT18HP7DB7) was failing when ice cream was not freezing. We cleaned the dust off the condenser, checked the...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 22, 2011 | Frigidaire FRS23KF7AB Side by Side...
My freige is to hot its at its lowest temp, 3 to 4 years old i vavumed a small bit of dust from lower
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | Viking Professional Series VCBB36 Bottom...
My fridge is acting up. The freezer section is very frozen and the fridge section is warm (room temp). I tried unplugging the fridge for 2-4 hours and after plugging it back in, it seemed to work OK for...
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
My Samsung Mdl #RS265LABP-XAA will cool the refrigerator section, then stop cooling. The freezer section stays cold. I think the refrigerator fans works intermittetly but I cannot find it. Where is it...
Freezer fan located in freezer section.
Try These
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
May 22, 2011 | Refrigerators
Over the past couple of weeks, my Side-By-Side Refrigerator freezer has not been running properly. It thaws out for a day or two, then it starts freezing again for a couple more days.
The defrost is not working.This happens due to the evaporator coil in the inner section of freezer is got blocked by ice .--------
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after couple of days.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 21, 2011 | Amana ASD2625K Side by Side Refrigerator
Fridge not keeping cold whats the best temp. we only have no.s 1 to 10.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 1005 reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
1 is the temperature thermostat, it actually controls the compresssor motors cycling,
thus box temperature as well, it often says 1-10 and off as well, the reamining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the refers box!
This is where the problems occur, when one notices the reefers box warm they max both settings,
which seems logical , and is for the thermostat dials setting.
Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!
Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!
not colder reefer! so you max or raise the thermostat, thats ok to do.
But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.
I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.
when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm too much in another day or so. But if the freezers making ice for days and never getting wet theres a airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it icedd up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?
setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons water.
Dec 27, 2010 | GE Profile PSI23NCR Side by Side...
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Ice melting in ice maker
Remove the food from the lower shelves , so the inside rear lower freezer panel can be removed ( only 2 or 4 screws ) .
The # 4 thermistor or # 5 thermistor is bad . # 4 tells the main control board , the temp of the coils , if they need defrosted and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on , due to temp setting .
May 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Frigidaire FSC23F7D Side by Side Refrigerator Logo
182 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
