Gateway ftw-l17m103 display dim - Televison & Video
2 of the (56uf, 25v) capacitors (C2 & C21) on the backlamps power supply board were weak.
Board Loaction:
Once the back is removed its the smaller board on the left side, C2 & C21 is located at the edge of the board.
Posted on Nov 21, 2008
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
I have a Gateway 450ROG with very dim video on the display, I can hook up an external monitor and the video on the external monitor is fine but still very dimvideo on the monitor of the laptop. You can...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 26, 2010 | Gateway 450ROG Notebook
I am looking for the power adapter for my model L17M103 TV. Where can i get one.
All you have to do is to read the specifications on the present one and get an exact duplicate one from any of the electronics store. Even Best Buy or Fry's would have them readily available.
Jan 28, 2010 | Gateway Televison & Video
A Gateway GTW-L17M103 will not power on, no power lights/menus.
Have you read the manual for trouble shooting? Is there a reset button on the unit?
Screen brightness is diminished?Video display devices experience degradation of brightness over the life ofthe device. Normal brightness degradation is not covered by your warranty.
You cannot see a picture?Make sure that the power cord is plugged into a grounded electrical outlet.?Make sure that the power button is turned on.?Make sure that the selected input source is connected to a working inputsource.?Press thecorrect input source.?If your LCD TV is connected to your computer in RGB or DVI mode, pressany key on your keyboard to "wake" your computer.You see a distorted picture or hear unusual sound?You may be getting interference from electrical appliances, cars,motorcycles, or fluorescent lights. Try moving your LCD TV to anotherlocation.The color is abnormal?Make sure that the input source cable is connected securely and correctlyto the back of your LCD TV.
Get schematics and look for fuse and voltage points
Feb 28, 2017 | Gateway LCD17TV 17 in. Television
Gateway gtw l17m103 light out
For the solutution repair of the Gateway Model GTW-L17M103 TV 1/2 lit screen - I was told by a local authorized Sanyo Flat Screen Repair shop that the lamp or bulb is going out and needs to be replaced. He said the replacement would run around $125. I have the same problem as well and now am seeking to purchase a lamp/bulb.
Dec 17, 2008 | Gateway LCD17TV 17 in. Television
Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Nov 14, 2008 | Broderbund Family Tree Maker 11 (382648)...
GTW-L17M103 LCD TV
perhaps a computer repair shop .
Dec 11, 2017 | Gateway LCD17TV 17 in. Television
Dim screen
If its very dark and you can barely see anything its probably a bad back-light. I'd suggest to take it to your local Best Buy. And yes, they can look up PSP#'s with your credit card, but even easier by telephone number.
Jun 24, 2008 | Gateway SL1450-30165297 Notebook
Lcd tv
blown capacitors on the inverter/ vga board
Mar 30, 2006 | Gateway LCD17TV 17 in. Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
