Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer display reads 8.8. ?????
I found the above display this morning when I walked in to do laundry.
  • Anonymous Dec 15, 2008
    Same problem try to turn on then 8.8. Appear. Unplug the the unit wait for a few minutes nothing happen...Help..
  • Anonymous Dec 29, 2008
    Same problem. could it be the control board?
2 Suggested Answers
sclarke7
  • 222 Answers
SOURCE: Is there a problem with Maytag Neptune Dryer
i have repaired several of these simply locate the screw that fell out at the interior bottom of the cabinet and screw it back onto the baffle this is pretty common
Posted on Oct 08, 2009
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Is there a problem with Maytag Neptune Dryer Drums. I have a customer who had one agitator fall off while doing laundry. I was called to make a vent repare and found the aluminum elbow attached to the...
Oct 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
the circuit in the control. you can get it at
http://www.apwagner.com/index.php?main_page=part_finder
I hope this helps.
Dec 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer screen shows 8.8. when I go to dry a load of clothes and won't work
We had the same problem - you might try and hit the panel with a blow dryer to heat it up if it's in a cold garage - it may buy you some more time - It took mine 2 yrs to go out completely - when it finally did - I took out the curcuit board and found dark discoloration around the cluster of four resistors - after reading dozens of posts from multiple sites, decided to replace those four resistors and the three main capacitors in the same area just to cover all bases. And for only a few bucks - it works like new again!!! A service call could cost you @$300 - $500 from what other are saying! eek if that's really the case!
Jan 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
35 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
