Question about Refrigerators
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
  • 1 more comment
  • Anonymous Nov 18, 2008
    I have the same problem. The noise is much too loud (vibration) for a new refrigerator.
  • jonchi Dec 21, 2008
    making loud noise lasting 5-10 minutes periodically
  • blgardner Jan 25, 2009
    My overpriced GE built-in is super noisy when the freezer evaporator fan is running, which is pretty much anytime when the kitchen is in use and the door gets opened. GE has replaced fan and motherboard and has now told me that new $6000 refrigerators are supposed to make that noise. Our 12-yr old side-by-side was not nearly this loud. I am at wits end and have no recourse. Will never buy GE again.
    Problem Solver:
  • 13 Answers
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Posted on Aug 26, 2010
  • Mark Aug 28, 2010
    OK, as promised I posted a short video of the noise, and how I make it stop.http://mistawizid.blogspot.com/2010/08/h...
Mine started this also. Bearing in motor assy is going out. replace the motor or the entire fan assembly. Couple different places I've found online for the part for under $40. easy self repair.
Steve
Posted on Jan 19, 2009
2 Suggested Answers
  • 13 Answers
SOURCE: Evaporator Fan Motor noise is
If the fan is always noisy, then it's probably is a bad fan. Easy to replace. But if the fan is quiet and purring sometimes, but buzzes like a demon when on high, then the problem is ice buildup. See a possible solution here.
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Got a ge profile seems the fz fan motor is not working..it's intermitinng..ya think it's that mother board?
Could very well the main board as it controls the fan speed be I have found several where the fan will only run on certain speeds
Feb 16, 2010 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Ratteling noise behind the ice maker on GE PSS26MSTESS
Sounds like a bearing is going in the evaporator fan motor. Remove it and check for excessive side play in the fan motor.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V Jenn-Air
Nov 22, 2008 | Refrigerators
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
3,443 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
