Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd-52531 has sound, then clicks off after few seconds
I purchased the tv 2 years ago. It has been used alot so when the first problems arised I figured they were do. The lamp indicator came on so I ordered a new one and replaced it. And it worked for about a month, but now it seems to be an intermittent problem. Usually, it will have sound then power off without the lamp igniting. If you keep trying to turn it on, eventually it will seem to work. The lamp indicator led doesn't always come on when power on fails. Is the replacement lamp faulty, something bigger, or any combination of items?
  • koyote101 Feb 03, 2009
    I have same problem . wd532531 I unplug than plug tv in and i hear what i thought was a fan noise like normal than sound comes on and than it shuts of than if i try to turn on again red light comes on i will check again and make sure i was going to buy a new bulb 175.00 but maybe thats not the problem it only lastesed 3 months thanks stephen
  • danni0323 Feb 16, 2009
    same problem going to replace bulb and see what that does
    Scholar:
  • 146 Answers
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confeirmed bad.
Posted on Nov 20, 2008
No picture
Lamp life for this model is 2 years or 2000 hours, less if a non Mitsubishi lamp is used, sounds like a bad lamp.
Dec 22, 2012 | Mitsubishi WD-52531 Television
WD-52531, a HD 52" TV
tv will not recognize cable box stations or channels
Mar 14, 2011 | Televison & Video
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Jun 29, 2009 | Mitsubishi WD-52531 Television
WD-62725 Need to reset to start
Good Day;
When TV will not turn on press the menu & input buttons on TV's panel, hold for 5 seconds. Count the blinks, eg; blinks 2 then pauses then blinks again. It should do this 3 times.l With that information respond back.Or the d-board is bad.
Good Luck.
Apr 21, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
376 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
