Question about Electrolux Washing Machines
I am trying to dry clothes using an Electrolux Washer-Dryer. EWX 14440 W. It dries them OK using Cottons-Drying and depressing drying time and increasing the time to say 90 minutes. One thing concerns me is that at the end of the drying phase, it says the buzzer will sound which it does. You can't open the door as it is locked before the anti-crease stage starts. This is also correct. However, it buzzes about 5 seperate times, not just once, indicating to me that something is wrong. After 10 minutes, you can open the door according to the instruction manual and I can. Just the fact it buzzes so many times though, is there a problem?
2 Suggested Answers
SOURCE: Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Posted on Oct 26, 2009
Keeps shutting off before clothes are dried
Most drying issue's are House vent related, Make sure its clean and strait as possible, and use metal venting only. Also make sure the vent hood on the outside of the house is clean and opening.
If your dryer is newer, make sure you not mixing loads, sometimes if you are drying cottons with heavier jeans, the cottons will dry faster and hit the moisture sensor and causing the dryer to turn off.
Mar 26, 2015 | Whirlpool Dryers
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 20, 2017 | Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Washing Machines Logo
46 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
