Question about Hotpoint First Edition FEW12 Front Load Washer
Door of washing machine will not open.
There is a half load in the machine. It has done a wash, pumped out and spun, but the door will not open as normal. I have left it after switching off for an hour but still no luck
First Edition 1200. WM29. (Hotpoint)
Can anybody please help.
  • Hotpoint Master
  • 3,463 Answers
Some times, you have to really pull hard to open the door
If no joy, then you have a faulty door lock.
To replace. remove door seal at front, thius will give you access to the door lock.
Posted on Nov 18, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Aug 15, 2015 | AEG Washing Machines
My frigidaire washing machine door won't unlock cycle is done but the door lock light is still on so I can't open the door
the machine still has water in it
simply turn the power off
wait five mins
you can open the door
manually drain the machine
and clean out the pump filters and traps
check the pump runs aok
wash the machine with cold water and no load
and check it drains aok
i think its drainage.. is the issue here
Feb 09, 2015 | Frigidaire Washing Machines
I cleaned out the water filter in my H2 and it washed with NO problems then I go put a load in after a few days and it now washes the whole cylce but the door won't unlock..and when I get it unlocked the...
The pump is probably not moving the water out of the machine fast enough. Even with cleaning the pump out I have seen where the pump doesn't work efficiently enough to satisfy the machine. Replace the pump.
Apr 18, 2011 | Kenmore HE2 Plus Front Load Washer
It won't drain or spin...and it stinks.
if machine washes...........but doesnt spin out water....then the pump is blocked.....
follow the waste hose into the back of the machine.......that is connected to the pump.
try getting machine to outside door.......
.let waste hose hang outside to drain most of the water out...
disconnect the pump half then unblock it..........job done.....
Apr 05, 2011 | GE WSXH208A Front Load Washer
The washing is coming out very wet, like it hasnt been spun, and sometimes the door will not open and you have to put it on an extra spin cycle or wash it again so it "finishes" and lets you open...
these are normally fantastic machines.
the metal flapping about does not sound good all the same, possible the drum is beyond repair........first of all get a basin and and put the waste hose down into it. this will siphon the water out of the machine and allow you to open the door. when you get the water out check the filter for a blockage. if you find plastic shards( grey color) in filter you will need a new machine im afraid.
Feb 16, 2011 | Tricity Bendix AW1000W Front Load Washer
Washing maching displaying a code F- 05 and door wont open. Looks like it hasn't spun either. What is going on?
Hello,An F-05 means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
May 23, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Open door
Turn off the machine and un plug, checked half hour later and the door opened.
Apr 19, 2008 | Whirlpool AWM8143 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
215 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
