Question about RCA F27440 27" TV
TV picture problems
My television occasinally losses picture.this is not quite frequent but suddenly the picture fades in and all of asudden the whole screen turns blank,but the audio is not affected.on waiting for some minutes the picture will begin to come back again,but some time on hitting the TV the picture will come back.i need urgent help!An email can be sent to me"getrigege@yahoo.co.uk".
    Scholar:
  • 119 Answers
This modle has a bad solder connection near the horizontal o/p transistor that causes the picture to fade in & out.the bad solder connection is on a small coil. the coil winding is typically red. looking at the back of the tv, the flyback has the rid wire going to the top of the tube, the horizontal o/p transistor is to the left & in font of the flyback, it's attached to an aluminum heatsink. directly in font of this heatsink is the coiul you are looking for, it should have a location id of L14XXX or L4XXX if I remember corectly. good luck.
Posted on Dec 08, 2006
SOURCE:
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
Picture fades to black when it goes to commercial
The sleep timer may be set to fade and a short time span.
Feb 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 21, 2007 | Televison & Video
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA F27440 27" TV Logo
130 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
