Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Water pooling at bottom, bad smell, and now doesnt appear to work
I get a pool of water at bottom of dishwasher. Water never dries and is above the mesh filter. I have already cleaned the mesh filter. The washer appears to not be filling up with water as detergent is dried up in block. is there anything i can check before having a repairman come out?
  • 833 Answers
My guess is the diverter solenoid which either pumps water to the arms or drains the unit.  It is attached to the waste line on the bottom of the tup.  It can often be disassembled and cleaned.  If not, it must be replaced.
Posted on Nov 20, 2008
The 2906 motor pump use oil
the oil that comes out is pool water and some thick lube
not sure if its suppose to be dry graphite
but i would not add oil , just dry from pool water
Jun 15, 2014 | Smartpool Dolphin Robo - Kleen Above...
The water has turned green despite the fact that we have been vacumning the pool every day. There is lots of algae on the bottom. It appears like the algae is not being killed by the salt water system. ...
How long are you running the system?? What is you chlorine level???.. To immediately bring your pool to the correct chlorine level, you either must up your cycle time, or shock your pool...I have a 18X33X48 pool..14,500 gallon pool and I run my system for 12 hrs and 10 hrs chlorinate and my water is crystal clear.. My chlorine level is in the 3 to 4 ppm.. If it climbs above 4, I lower the cycle time...After you shock or up your level, vacuum again to remove all the dead algae.. If you live in an area that is hot , you will need to run longer cycles.. Right now temps are ranging from 95 to 111.. yes, very hot... I hope this helps you and good luck...
Aug 27, 2011 | Intex Automatic Salt Water System for ...
I have an 18" round
Get a pool brush and brush your pool daily with it. Make sure your Chlorine level is at least 5 (I would like to see it at 10). Add dry chlorine to yor ool if you have to to get it to this level.
Alternatively, brush the sides and bottom daily with a hand brush. Keep the filter tunning until the algae is gone.
Aug 02, 2011 | Intex Automatic Salt Water System for ...
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Feb 02, 2011 | Dishwashers
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
384 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
