You can try one of the industrial strength radiator cleaners like Radiator Cleaner. According to the manufacturer: "Radiator cleaner removes the dirt, grease, scale, grime & solder from the engine cooling system. Radiator cleaner is a powerful cleaning agent not only for the automobile engine but can be used for the steam tube and boiler tube etc. Radiator cleaner not only clean the clogs of the system but also keep the system in order to run for a longer period. Radiator cleaner clean the system fast easy and safely without harming any part of the cooling system."
Advanced Petro-Chemicals' website can provide you full instructions. If you are interested, please CLICK HERE
SOURCE: 1999 GMC Jimmy Running Hot w/ Engine coolant reservoir empty
Hi
The problem is most likely 90% head gaskets but could be intake manifold gasket leaking too. Intake gasket has to be checked when intake is removed. Might find problem there if not continue and remove heads. Bars Leak will not work.
SOURCE: No heat in 98 jimmy. Replaced water pump,
Possibly.. the actuators which operate the doors actually have a position signal for reference, but the actual motors inside the actuators dont realize there is a limit and overshoot their limits causing the fine wires inside to rip apart rendering the actuator scrap but this happens when actuators are still plugged in to the connector while being taken off the heater door, and they can and will still move with the key in the off position if the actuator thinks it not in the proper position..thats how they work anyway.hope you had them unplugged untill the last, then this would'nt happen....hope this explaination helped
SOURCE: replace water pump on 1997 gmc jimmy 4.3 litre
there are four nuts that you must remove at the front of the pulley between the fan. remove fan, fan shroud,loosen accessory belts. remove water pump pulley and the pump bolts will be exposed. check belts for replacement while you have them loose. reverse procedure to install.
SOURCE: 1989 Chevy Suburban keeps overheating...have
try to see if ur heater core is pluged up sumtimes that can cause ur car to over heat. hope this helps
Testimonial: "Never thought of core being plugged...Thank you"
