Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
I loaded a 2x3 light area rug into my washer and went to drop off my daughter @ school. when I returned home the washer was not working and the time indicater was flashing a code that read ( f- ).I then tried to open the door it did would not open...I read that I should enpty the water from under the washer I did and nothing happened.I even tried just to unplug the washer and nothing happened..........need help please
note: my whirlpool duet sport 27" washer model number is wfw8300sw
  • 1,028 Answers
Without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Posted on Nov 19, 2008
My front loader door is locked and will not open, I have tried to restart, unplug and everything the machine is turned off and the door still will not open.
First unplug the washer. Remove the front valance under the door (three screws at bottom front of machine) reach up inside by the door lock area and there will be a plastic tab, pull that tab down and that should unlock the door.
Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have the whirpool duet sport washer & dryer and everything I wash in the washer smells bad. The washer always smells not even washing with the pure bleach cycle works
Odors related to front loader washers is a common problem. The following link gives some pointers on things you may try to minimize odors and to keep them reoccurring:
Many of these tips are mentioned in the owner's manual of these washers. The most important factors inlcude:
1. Leaving the door open when not in use.
2. Checking for small garments that end up in the door bellow area.
3. Using HE detergent only.
4. Checking the drain pump reservoir for debris.
These simple factors will not only minimize odors, but will keep them from coming back. I personally own one of these front loaders and have never had an odor problem in the 9 years I've owned it by following this regiment.
If you have your doubts or have questions, please post back and let me know. I do hope you find this information helpful.
Mar 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
626 people viewed this question
Dan Webster
Dan Webster
Sal De
